Help R34 Fuse Panel - Translation please!
Hi Guys,
I've just picked up a 34 GTT and have no front wipers.
I can't see any blown fuses.
BUT, I have some fuses missing from the interior fuse panel.
Can someone please check this out this attachment (1 page PDF)?
Looking mainly for wiper fuse location, but if you're feeling energetic, I'm sure posting the full set will help out some of the ppl.
Thanks heaps!!
PEAR
Here's a sample of the 33 Fuse Panel - but I can't find anying on the 34.
SKYLINE R33 Fusebox
In Cabin Fuse box:
Left column, top to bottom
10A REAR WIPER
10A ANTI-STOP (ABS PERHAPS???????)
10A STARTER INDICATOR
10A ROOM LAMP
10A STOP LAMP
10A ELECTRICS
10A ENGINE CONTROL
10A HAZARD LAMP
15A FOG LAMP
10A TURN SIGNAL
10A METERS
10A ELECTRICS
Right column, top to bottom
10A SHIFT LOCK
10A A/T CONTROL
10A AIR CONDITIONER
10A ENGINE CONTROL
10A AIR BAG
20A BLOWER MOTOR
20A BLOWER MOTOR
10A AUDIO
15A CIGARETTE LIGHTER
20A FRONT WIPER
10A MIRROR CONTROL
20A REAR DEFOGGER
Ok, on the PDF, location #6 IGN 20A 'Front Wipers'.
It seems odd that they don't work... for an R32 or older it seems possible but an R34? I hope it's only a fuse thats the problem.
Thanks!! yes, fingers x.
from memory, I think #6 was missing.... I hope,
I know some where missing (2 or 3), I list them, would you be able to translate them too?
Thanks again,
PEAR
Was a missing fuse - wipers are now working!! Thanks.
The 3 blank spaces lets look as though they are ok.
Rezz, thanks again!!
PEAR
Interesting! Where is the interior fuse box? I had a quick look the other day and couldn't spot anything :thumbsup: Also, can anyone give me an idea as to whether the cigarette lighter is listed there? :P
#23 ACC 15A 'Cigar Lighter'
  • 2 years later...
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
