If you're trying to save money, trading in your non turbo Skyline for a turbo Pulsar may not really change your Total Cost of Ownership, especially if you're going to modify it.
Turbos (especially the GTiR, which has a reputation for overheating) need a lot more TLC than a NA car.
Sorry, im not intending to buy the GTiR just yet. Im selling my skyline to finish off paying my car loan cuz i hate the interest rates. By saving on the interest rates (12%), i'll have enough money to buy a GTiR within six to eight months. By then my financials will all be soughted out, i just dont want to get a bad credit rating should i ever get so bad that i default on my loan.
dude pocket rockets go off, you can make them look good just like any car, just dont go OVER the top with cosmetics and it'll end up lookin' classy and not like somethin off a st corner in st kilda lol.
the bonnet is hideous and the rear looks very plain...
good motor ... glass gear box ... ugly styling ... performance potential ...
if you dont mind spending a bit of money to get her up and going nice as well as looking nice ... buy one. Otherwise just buy a n14 SSS or sumfink <---- they look ok and are fairly cheap on fuel, good luck finding one with low k's on it however!!!
seems to me your stuck between a rock and hard place ...
GTI-Rs are a great car. I had one for two years. a lot of the problems people mentioned are now not so bad. there are plenty of off the shelf performance parts for them now as they are much more popular than they were 2 or 3 years ago. in the two years I had mine it saw plenty of 7000rpm launches and never had a clutch or gearbox problem. also dragged it at WSID once and went to a few track days. I spent a fair bit of dough on the brakes and suspension as they go very hard stock but don't stop and turn so well. with some mods on brakes and suspension though it will be a very nice package. then spend a bit on power upgrades and it will be damn hard to beat.
don't expect it to be cheap, because the fact is it's AWD, and turbo. those two things tend to bump up associated running costs on any model.
very fun car to drive though, and a much better SR20 than found in silvias etc (ie. solid lifters, longer duration/higher lift cams, 440cc injectors, bigger turbo, quad throttles, 19mm conrod bearings and on and on.)
if that is what you have wanted i say go for it.
two words
Plough Understeer
Generally followed by snap oversteer. Not a good handling trait in anyones books.
Even with the white line suspension works package it will still tend to understeer and snap, it's just a little more controllable......
    • I see... Any idea how much fab work is required? I note the Hygear megathread but its like 900 pages
    • I should try the experiment you're talking about, the throttle switch is still there carried over from the R32 and it's still all wired up but after I did the whole intake manifold refurb and had to recalibrate the TPS I managed to somehow get the idle switch reporting activation at 0.22V, then when I adjusted it to 0.45V for idle it decided the engine was permanently no longer idling which caused some very weird behavior, closed loop idle was disabled so it would basically be at the whims of the cold start valve and whatever the base timing table was at. Then just unplugging/replugging the TPS with the ECU live caused it to relearn the idle TPS position and decide 0.45V was idle. Presumably there's nothing in the TPS that allows for the throttle switch to "recalibrate" like that, not easily at least.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
