Hi,
I have just finished my s13 rb26dett conversion and are having promlems around the intake/turbo.
The engine has two new garret gt28r turbos,z32mafs and apexi pfc.
The intake pipes are 60mm ss directly to the turbos.
The problem I am having is that it sounds (and feels) like the intake pipes are blowing air out again in a pulse: front ,1sec, rear,1 sec, front,1sec.... and so it goes on.
Does anyone know why this happens?
Should there be a balance pipe between the intake pipes?
(I dont have the original ones to check)
the engine is running very ritch because the registrered air comes out again.
Here in norway there is not more than around 10 gtr,s so nobody has knowledge on tuned rb26 engines.
Any tip/help will be apprechiated alot!!
https://www.sau.com.au/forums/topic/77725-intake-problems/
does it do this when it's just idling or what? sounds like reversion (large volume of compressed air being pushed back past the compressor wheel upon gear change) but that shouldn't make the car run rich, maybe just for a sec when shifting.
only other thing i can think of is that your idle is too high, but either way that's a very strange problem.
balance pipe should not make any significant difference if it's on the intake pipes.
https://www.sau.com.au/forums/topic/77725-intake-problems/#findComment-1420378
Does this happen when it is idling or when you are driving? What rpm does it happen at? Is it at all rpm's?
Things to check;
Spark plug gap, if is is misfiring it will cause the turbos to surge.
Camshaft timing, if it is too retarded on the inlet or too far advanced on the exhaust you will get surge
Ignition timing, similar to camshaft timing.
Valve clearances, if the inlet valves are not closing you will get combustion pulses back through the inlet. If the exhaust valves are not closing you will get combustion based pulsing of the turbines.
Hope that is of some help:cheers:
https://www.sau.com.au/forums/topic/77725-intake-problems/#findComment-1420424
Interestingly enough I was talking with someone recently about GT28Rs on an RB26 - and they reckoned that unless you go a large turbine a/r (and therefore a pretty laggy twin setup) they are quite "surgey" turbos as a twin turbo configuration. If you are running ~.64 turbine a/r, then what he was telling me is true... ;)
https://www.sau.com.au/forums/topic/77725-intake-problems/#findComment-1420533
the problem is there both on idle and driving.
the blowing pulse dont seem to rise when reeving the engine, but it gets stronger the more load you give it.
register belt are checked, plugs, afms and o2 sensors.
I have tomei 260 cams with adj. pulleys but they have not been adjusted yet.
The head has been ported, gasflowed and rebuildt.
I believe the valve clearence is ok because I cant hear any tikking or bad sounds from the engine.
Can I find out more about cams and lift If I take a compression test??
Lithium:
What do you mean about "surgey" ?
The turbos are almost the same as the hks 2510,s so I dont believe that they are the problem.
https://www.sau.com.au/forums/topic/77725-intake-problems/#findComment-1424578
he means when you close the throttle or back off the charged air in the intake blows back out the turbos...compressor surge.
Are there any blow off valves fitted to the piping for removal of surging?
ok. thank you for explaining, my english is not the best :whatsthat
Yes, there is a hks racing type bow fitted.
But it doesent only happen when I release the trottle. It happens all the time in both at idle and driving.
Is it possible that the air can come back in reverse when the turbine wheel is blowing the other way?
I believed these turbos have been tested as twin before?
Belive I,we read on this forum that someone used 2x garret gt28rs.
Can anyone confirm this?
Is there a good way to check if they are too "surgey"?
https://www.sau.com.au/forums/topic/77725-intake-problems/#findComment-1427023
Thats reversion, not compressor surge. Compressor surge is where the turbo(s) is trying to pump more air than the engine can swallow and so you get the chuffing sound as the air bounces (for lack of a better term) back through the inlet. On a single turbo setup its commonly associated with turbos that have very large compressors in relation to the turbine.
https://www.sau.com.au/forums/topic/77725-intake-problems/#findComment-1427703
Checked the compression on the engine yesterday, and it was a pressure of 7 bar on all sylinders.
The engine manual says 12 bar original and a limit of 9bar.
engine is a r33 with only 39000km on it.
It looked like new with original turbos when I bought it so I dont think its the bottom end.
The head has been ported and fully rebuilt With new 3 angle seats.
The man who did this says its been pressure tested too.
But thats without cams and lifters.
Right now I am starting to believe its the valves not closing entirerly and causing the low pressure and engine trouble.
Anyone else with me on this one?
Is there a way to check this without taking the entire engine out?
Is it possible for an engine builder to shim the lifters in the right posision with head and bottom end toghether?
I Must say I aprechiate your help alot!
https://www.sau.com.au/forums/topic/77725-intake-problems/#findComment-1438309
  • 3 weeks later...
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
