guys as I am sure most of you are aware I got an FMIC and have been fitting it over the past couple of days. Everything’s all good with it however the new piping doesn’t come with that little nipple thing (this is the n00b part).
On the stock IC piping I have a bit of rubber piping running to my bleed valve to determine how much air to bleed out etc however the new piping doesn’t have the little nipple thing to attach it too. Can I just take this piping to any metal/exhaust place and get them to make it up also as an alternative I am sure that me and dad could weld one onto it but were do I actually get the nippily thing.
PS: I am aware I have said nipple alot don’t get to aroused people. :boobs:
https://www.sau.com.au/forums/topic/77731-n00b-question-re-ic-piping/
Leech i had the same issue a week or 2 ago. Just buy a brass nipple from autopro and either bolt it or weld it into the IC return pipe.
have a look at mine as i am sure it doesnt have one either but i have a bleed valve.  Come to trivia
ahhhh what time you going to be out their as you must have somewhere a line that runs to your bleed valve from the ic piping otherwise how does it know how much PSI is going through. i have shit to do tonight but i might be able to pop out for like 30 minutes to have a squiz
Yeah you definately need it, it runs (via your bleed valve) to the boost control solenoid/wastegate actuator...mine does anyway.
yea thats exactly what i thought without that wont it just majorly overboost ??? as it will have no idea how much boost it will be running.
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
