Cam Gear & Dyno Tuning Results @ Croydon Racing Development
Hi guys,
These chinese whispers are true...
I was always expecting that I will need to attend to the 'weak point' of the car but no sooner than 6 months (I was hoping this anyway)
Cause? could be a no. of things:
- bad batch of fuel
- overheating due to lack of capacity of standard radiator
- blocked injector
etc....
I was quite lucky to catch this out in its infancy, the compression dropped in cylinder 6 down to 79, othe 5 cylinders were reading a consistant 140+.
As the engine is undergoing a total recondition with forged pistons, billet con rods, honing of cylinder bores, crank balance etc...my mechanic will be testing the other items for malfunction.
I can't wait to have it run-in once again :(
Marko.
Ouch...was it pinging?
  • Replies 81
Posted Images
I have been advised ringland damage.
It was breathing extremely heavy via the catch can.
I am more than happy to build the bottom end that way I can rest easy & not worry about it when i blast it!
What is the general consensus on these options considering the power I am running:
- standard rods with arp bolts
- forged rods
- billet rods
i guess if i do want to run race fuel i will need aftermarket rods, if i keep it on the street though with over 350awkw standard will be ok, thoughts???
Guest DIRTgarage
- forged rods
- billet rods
We run fully prepped stock rods in our car i.e. cryo treated, shot peened, closed and honed , ARP bolts etc. Rev the car to 9 grand and the engine has not missed a beat in 18 months. But.......if i had my time over and could see the sort of development stage the car is at now i would go aftermarket....no longer just a road car....but back then it was. Whats your crystal ball telling you?
Hi Paul & Stace,
for the moment my car will be street driven with the vision of 'maybe' running it on race fuel (only once or twice) just to see what it is capable of...other than that it will be guzzling pump fuel!
dart automotive is rebuilding it for me.
nick, dart has sourced for me arp rod bolts
car will be ready this fri
Marko, can I ask where you're getting the motor rebuilt?
  • 3 weeks later...
Marko, thanks for that, I will give Jim a call about them
Nick,
Have u dropped ur car off with dart as yet?
I now have 300km on the clock - another 1200km before I can boost it again for REAL power :)
Marko.
Guest DIRTgarage
Nick,
Marko.
good to hear she's back on the road Marko....what rods did ya end up using?
G'day Marko :)
good to hear it is all back in 1 peice, for interest sake I did a power run at DART yesterday....
I have an overlay of the torque curves too :)
and to all reading, I was on 19 psi and I think marko was on 13 psi.... so peak isnt really a factor but I made 585NM
interesting to see where the RS Vs SS come on etc.. ;)
hope to see you soon, before I split to Adelaide...
Im the green line....
Nick,
Marko.
Hopefully within a week or so Marko - All ready to go now.
G'day Marko :)
thats a great result, mine on that run was around 12.8psi
when i was running 23psi it was just short of 800nm of torque - this running in period really sucks...
can't wait to see what it makes at DART when you have the 23 psi again!!!!
that dyno room is the business!!!
for sure - that setup is state of the art!
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
