anyone have a Heat gun I can borrow for a day?
Trying to make home made Cold Air Induction on my N/A car...
I just need to bent few PVA pipes, I mean PVC pripes...heheh :D
also Open to suggestions...
because I dont have Turbo... the hole where Stock intercooler piping goes is closed off, so I am plan to cut hole and feed a pvc pipe and close rest of pod filter and O2 censor with soem clark rubber heat sheild!
cheers
Joe
https://www.sau.com.au/forums/topic/7775-a-heat-gun/
Ok having trouble with all the materials...
went to clarks rubber and burnnings to get some inspiration for the CAI...
I have found 3meter silver coil vent induction pipe but they cost too much and let alone dont need 3 metere/$21.60.
Found nice silver sheet of aluminium $18.23 or some thing like that, quite suitable...
found foam with silver lining but it also pretty fragile, not sure how it will hold with all the heats from the engine...
my best option is to go with aluminium sheet for the box and for piping...
saw few PVC pipes but hey are booldy heavy and there is not many choice to shoose from, they are rock hard and not sure how malleble they are with heat gun... but I shall try!
anyway thanks for reading... you polly think I am stingie one but yeah I am student with no $$$ :lol:
BTW can anyone show me how to take off the Front stock spoiler for series one?!?
cheers
Joe
https://www.sau.com.au/forums/topic/7775-a-heat-gun/#findComment-116536
Joe, the air duct stuff from bunnings is bloody expensive, try an airconditioning supply place (sorry forgot the name of where I went, but it only cost me $11 instead of $21). That foam stuff from clarks seems ok in my car, haven't had probs yet and you have to buy it by the lineal metre, so enough for 2 partitions.
Maybe someone will go halves on both and save you even more dollars (sorry I already gave my leftovers away)
Steve
https://www.sau.com.au/forums/topic/7775-a-heat-gun/#findComment-116540
    • I definitely do recommend having a fab/grinding/dirty shed or area to keep all that grinding dust out of your main shed.Ā  But you're right, it doesn't matter how much room you have you still end up filling it! I might even do a short video which will make it easier to fully take in the horrors of what I've created...
    • Actually No, Iā€™m not as intuitive as u
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. šŸ˜­ I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
Ɨ
Ɨ
