OFFICIAL RESEARCH BY MYTHBUSTERS:
Mythbuster proved last night (last night in WA - on TV) that it is more economical to drive whith your windows down than with ur windows up and aircon on flat out
two suv's with the same payload with 5 gallons of petrol where sent around a track to find out which would stop first.
suprisingly, the car with the aircon on was the one to stop the first
the other suv went for a further 15 miles
the reason that this is suprising is that one would have thought that the drag created by all the air being sucked into the car with the windows open would have made it slow down first, BUT, mythbusters have shown that it is more economical to drive with the windows down
So there u go fellas - windows down then in the future seems the way 2 go!!!
:):rofl::) :cooldance
https://www.sau.com.au/forums/topic/77761-mythbusters-research/
yea that true that aircon sucks power,
but one would imagine that the drag factor created by all the air pouring into the car with the windows open would make it less efficient than with the aircon on
and of course this would change from car to car
a small car with the aircon on full blast will drain alot of power and fuel, but on a big car, like the suv's that they where useiong (ford explorer xlt's i think - if i remember rightly) you would think that it would be more efficient for the aircon to be on, than the wiondows open
but hey, it is interesting
PS:
is anybody willing to do some test with there skylines - it would be interseting to see what the diff is (by tests i mean like 5 litres of petrol and see how far u go sort of thing at a constant speed)
  PHATR32 said:
i always drive around with my windows down.
how else can chicks listen to your fully sik bass while you cruise around with your arm out the window?
too true mate, too true
:bahaha: :cooldance :bahaha: :cooldance :bahaha:
  predator said:
they always said aircon sucked the power.. haven't u ever put on aircon whilst climbing a big hill in a small car?
But this test was based on cruising on the highway. Stop start driving and hill climbing are not part of the conditions where this myth was thought to be true.
But I think the caterpault was f*cken funny sh*t!!!
Especially the way it fell apart afterwards....
What surprised me about this episode was that it was a myth. I watched this with a mate and we both assumed it was common knowledge that running a car with the a/c on would use more fuel than just having the windows down.
That trebuchet was funny as... poor buster!
they should have filled the bucket of that crane with watermelons or a dead cow get the most out of it:D:D
werent that bright were they when they first decided to fill the cars up full and drive for 7 hrs...lol...then having to pump it out by hand...haha.
ACA did a test yesterday too on how much k's u can get out of regular, premium, and super premium. they were smart enough to just fill the cars up with 5ltrs to run em dry. the only smart thing ive seen from that show.
Its not that surprising, really. It also doesn't help that SUVs have the aerodynamics of a brick shithouse, so making the aerodynamics slightly worse has less relative effect than making the engine power a compressor that's not increasing the air density going in to the engine.
Try the comparison on a car with a low drag coefficient, and it would probably be a lot closer.
Hey B1, I missed ACA, can you give me a quick run down?
I personally think that the "lift drop" did more damage to Buster than the "crane catapult".
  Quote
but if its sucking power, its still sucking power, it just becomes more obvious when you are climbing a hill and the car has very little power.
like writeoff was saying, most people would say that if you asked them regarding the aircon that it draws more fuel.
I am pretty sure *any* car with aircon on, you'll notice worse fuel economy, as the compressor is creating drag on the rest of the belt system, and hence the whole engine turning over, requiring slightly more power to get the same result.
Hey guys i think we are forgetting that the research they did was a bit flawed. I thought it was a widely known fact that it is more economical to wind ur windows down compared to use the aircon, but only up to about 80km/h. This is the point when the extra drag created by the windows being open becomes greater than the power the aircon uses.
In the first test on mythbusters, run at 55mph = 89 km/h, they found that it was more economical to run the car with the aircon on.
In the second test, they ran the cars at 45mph = 72 km/h, because it wasnt safe to go around the track for that long with their shit SUVs. In that test they found it was better to go with the windows down.
It was the difference in speed that made the difference, youre still better off with the windows down at speeds up to 80km/h, then using the aircon at speeds above that.
Rhett
i didnt get the point of it - i thought it was common knowledge that the a/c sucks power (therefore uses more fuel), you can tell as soon as you turn it on.
I used to own a BA Falcon XR6 with the instentaneous fuel readout display, if you held it steady on the the freeway at 110km/h it would read about 10L/100km, winding down the windows made no difference, turning the air-con on, it would instantly jump to 12L/100kms.
sure, unleaded konked out first then super unleaded(98ron) a good couple k's more and suprisingly premium(95) did a couple more k's then died in the ass. was a good test as it wasnt on a straight but normal roads with ups and downs and sharp turns and everything to simulate normal driving.
Cool, thanks for that. not that it will stop me from using premium(98)
i think that they should have put a bit more thought into it..
consider this.. i know 2 people who have the same type of car.. one of them would stop after using 52L in the tank, the other after only 47L.
Reason: the fuel pickup was mounted slightly differant.. from the factory..
the fact that they pumped out the tank completely tells me that the test was not well done.. it would have been better to drain the tanks completely, add a little fuel and drive the cars around till they stop.. this would be the true empty point of the car.. there may still be some fuel in the tank but the pickup wont get it..
then with both cars at this point conduct the rest of the test as they did..
my $0.02
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 馃槀  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
