As the topic said, my R33gtst starts then immediately stalls. The car will stay on if i play with acellerator pedal, though as soon as i take my foot off when the revs come down it stalls.
Ive check it for spark and injector pulse when stalling and its all fine. Fuel pump is buzzing away fine, i tried starting it without the airflowmeter pluged in and stalls at the same time an stays on if i play with accell pedal. I had a spare airflow meter, chuck it in thinking it would solve the problem but hasnt. IS it most likely the TPS?
I dunno but im a little unsure how to check my fault codes, ive removed my LH kickpannel to reveal my ecu. Im aware i need to put it in self diagnostic mode (mode 3) however cant see any led's or somewhere to select which mode to go into. Do i have to remove my ecu to do this because i cant seem to see anything on the side of the ecu that face out into the car.
Any help would be great with extracting the codes, not what each code number represents but just how to extract them ive already found heaps of info on that just no luck with now getting the codes
https://www.sau.com.au/forums/topic/77764-imediately-starts-then-stalls-r33/
  • Replies 44
cheers il pull out my ecu, i thought it may of been on the other side but seemed silly cos it should be quick and easy to extract codes
yeah it seems like there a big air leak intercooler pipe orsomething
il have a better look around, the other thing i just sort of remembered is a couple of times its stayed on for a minute or so. which leads me thinking its a component rather than a vacum leak
Further investigatrion, and still no fix. My friend of mine who works at a nissan brought there scan tool around, the results. Nothing??? Whilst doing that i check all vacums lines and cooler piping and still nothing. There is nothing in my mind that can be obvious, there was no fault codes in my ecu, all the components i had some doubt about all were operating with in there range with correct voltage, and the graph there scan tool can display over time all appeared as normal, except maybe my o2 sensor was not a 100% but as would any o2 sensor that is still the original from factory. Also it should run even without that.
Im able to run the car with my foot opening the throttle as it tries to stall. So i could test all components at operating temp with the nissan scan tool as supposed too. Also if i sit there reving it anywhere above 2 grand but more like 4 to 5 grand for longer than 15 seconds, the car can hold an idle from anywhere from 10 seconds to say 45 seconds at most after its back to idle and my foot stops operating the throttle.
Anyone with some insite that would be great, another thought i had of what it may possible be is the 'Idle Air Control Valve' however it sort of make sense, i dont know how to check diagnose this correctly. Has anyone got some idea? feeback appreciated.
Sounds more and more like fueling issue.. mine was same sort of thing.. would die at low revs.. once got going was ok, but could cutout at the drop of a hat. Took me a week of trying nearly everything to diagnose it.
Unfortunately I didn't have a scan tool to look at sensor voltages, etc correctly (something i must get soon) - but i think if you monitored duty cycle you'd see it suddenly dropping off before the engine cuts out
My ECU was reading same "all fine" even while the problem was occurring.. the stock ecu is not going to tell you a fuelling problem basically... as i don't think its part of the monitoring loop (unfortunately)
p.s. a fuel pump can still make noise, even if its fooked.
It could also be the fuel pump speed control circuit.
I don't know exactly how the r33 runs it but on a 32 you have a big dropping resistor in the engine bay. if that is unpluged you have exactly the symptoms you are describing.
Basically, when the car is at idle it tries to drop the fuel pump speed, goes open circuit, puts no power to the pump and the car stalls.
You can chop the fuel pump speed control wire at the ecu (if you dont mind chopping wires as a check) and the car will then run the pump at full speed all the time. If it doesn't stall then you know the problems is with the speed control.
You could also listen for the pump when you have the car running, if it suddenly stops when you let the car return to idle then it could well be the same thing.
There are also some aftermarket pumps that dont like having a lower voltage and could be struggling to pump the fuel (if you have one that is)
hope that gives you another lead to follow anyway.
Cheers
Cheers guys thanks for your input
paulr33
You car should run without the airflow meter, it wont really drive but will hold idle.
I always thought car will stall without afm but when we tried it on my friends R33 the other day ran fine at idle, also i had a spare an chucked it on straight away an nothing.
predator
Cheers for your input, im glad your thinking fuel. It seems logical to me also, what about fuel regulator being faulty??? Could this be the cause. I know what you mean by the fuel pump also, they have a tendency of shitting themselves especially if its buzzing becomes louder. The fuelpump is the standard item and im pretty sure its not the problem, however touch wood. Il have to do a fuel pressure test which i should have already done however i dont have the gauge.
BHDave
Thanks thats another logical possibilty 'fuel pump speed control circuit', something i know very little about but definately worth looking at it tommorow. Thanks for the explanning. However my only doubt being when the car stalls you can still here the fuel pump buzzing away when you put your head next to the tank cos the ignition still on. However it could stop for a couple of secondsthen run on again straight after, hence being faulty the 'fuel pump speed control circuit'.
Thanks guys
when my car is running and i unpug it, immediate stall. when i start car with afm unplugged immediate stall
Thats right, coz as the afm plug is unplugged the ecu wont detect the air signal voltage so it doesent know how much fuel to add so it will stall.
If you ever go for a epa test this is 1 of the things they also check
Ok i had a good look at quiet a few things on the weekend, yeah thats right about the afm i think mine limits at 2500rpm. It will run if unpluged before started. So the other day i had cleared all the fault codes with a nissan scan tool, so on the weekend i recheck it for fault codes the old fashion way with leds. It came up with nothing, code 55, like predator said codes wont tell me much.
Anyways my friend at nissan told me to clean my throttle body out and to adjust base idle again and it may not stall, he seemed to think it was very important to adjust the base idle. I had cleaned my throttle body the other week but never readjusted the base idle, so i tried to however appeared to be fully adjust as low as possible manually. So i adjusted it out a bit to idle at 1400rpm an know my car holds idle, the idle previously was 800rpm at operating temp, so that should have all been fine. I adjusted it back down when warm at what it should be and it began to stall again.
So i look into BHDave and Predators advice about the fueling issue, it seems as though BHDave may be onto something, i listen in the boot to see how the fuel pump was operating it was running then all of a sudden for about 2seconds you would here the pump switch off, then as the car would stall the pump was switching back on.
So now i need to find out where the fuel pump speed control circuit is exactly, how to fix for the problem, and im really curious as to where this big dropping resistor is in the engine bay is exactly?? And after all that about the last 15 start ups it hasnt stalled, however im not one to ignore the problem so i need to find the fix even if its not doing it now.
So anyone with any knowledge of fuel pump speed control circuit would be of much help.
Thanks guys
Im currently having a similar problem, except mine will idle for awhile then just drop in revs and stall for no reason.
Its definately something to do with fuel, i just drove for 30 mins without a problem.
But then went to accelerate after turning and stalled again :(
tis always something simple, just gotta find it
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
