Hi all...
I have for sale is my 3 weeks old Wolf 3D v4 computer for R33 GTST. i'm selling my car and decided to put the stock ECU back to get more money.
here's what you get
Wolf 3D v4 ECU
Hand Controller
Software and cable so you can tune it using the laptop or simply use the hand controller..whichever you prefer.
and USERS MANUAL.
Ok..here's the deal :
Wolf was tuned by Mercury Motorsport in Brisbane 2 weeks ago-- paid $700 with receipt for the dyno tune...so basically saves you alot of money in tuning..just plug and play pretty much...no more tuning required..unless your mods are diferent than mine.
My mods are pretty basic ;
3' turbo back exhause with hi-flow cat
FMIC
boost control set to 10psi.-- ECU has built in boost controller that is set to 10PSI
nismo air pod
and the rest are stock standard
asking price is $1250 ono
any questions pls. PM me.
https://www.sau.com.au/forums/topic/77848-wolf-3d-v4-with-hc-ecu-for-r33-gtst/
How does it drive????
If u have it by next week... i'll prob take it off your hands, because i get paid by then!!
Hi all...
here's what you get
Wolf 3D v4 ECU
Hand Controller
and USERS MANUAL.
FMIC
nismo air pod
I agree.. it would be better off get it retuned if your car has any other mods.. still saves you some bucks on tune up as it's basically been tuned to the cars current mods.
and she drives like a dream...she just kept going... i earned extra 25kw at the wheels with just the wolf.
also...wolf has a built in turbo timer.
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
