I am gunna have 2 batteries, the one under the bonnet and one in the boot for stereo powa. The battery under the bonnet at the moment is a 360CCA, I think.
how do I hook up the second battery?
I am pretty sure it has to connect to the alternator so that it charges while the car is on (forgive me I am a n00b at this). So if assumption proves me well I can just connect it to the fron battery because that one is already connected to the alternator, right!...and ground the Optima to anywhere on the body, right!
............have I just created this thread for no reason?, I'll post to be sure.
is the above right?
https://www.sau.com.au/forums/topic/77866-connecting-optima-for-stereo-only/
ahhhh u could do that or.....
get 4 gauge wire travel it from battery from front to back and put isolater solenoid about 30-40cm from batter from the same line. use 4 gauge wire from negative of rear battery to a solid point of the chasis in the boot somewhere
i think thats about it oh and use 2 fuses one at front battery and one on rear battery
thanks SERIES_II, thats what I think I am gunna end up doing anyway....
where do I thread a piece of cable from the front to the back running through the firewall?, I could see no points of access through it.....
are those isolator solenoids what stop the sudden backward surges of power?, had a mate tell me about those yesterday and that I needed one for my setup
only 4 gauge? Shouldn't you run 0 gauge wire?
thats a good point actually, I think I will get 2 Gauge for it as I am running 2 Gauge from my Optima to the amps and 2 Gauge ground....I always thought 0 Gauge was overkill
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
