I cant make up my mind...what shoud i do?
Shoud i shave R32Big_boy's head while he sleeps this Saturday night, should i put a blonde rinse thru his hair...perhaps slip a few kgs of fresh prawns into his bed :confused:
I could always stay up all night singing Henry the 8th, but, i figure if i brought some kerosine on the trip i should be right to do some body piercing! Or perhaps a big hunting knife to cut a little Z into his forehead.
What do you think?
https://www.sau.com.au/forums/topic/77868-decisions-decisions/
cornflakes go well in someone's bed or sleeping bag. thanks for iniviting us (and troy) but can't make it, have gf's bday, gf's mums bday and a another friends bday all on the same weekend. will do my best to get pissed a lot though :)
I wont be doing anything 'to you' ... ill simply be doing something 'for you', something you know you have wanted for a long time but cant muster the strength/courage to do for yourself...:thumbsup:
There will BE NO SLEEP THIS WEEKEND, and remember if your going to bring snacks, then lock your fridges once you have gone to bed:)
I wont be doing anything 'to you'  ... ill simply be doing something 'for you', something you know you have wanted for a long time but cant muster the strength/courage to do for yourself...:)
I feel another Midnight Raid coming on......
Do what we did to one of our friends for his bucks party.
Shave all his pubes, leg/arm hairs off and replace it with food dye.
Then tie his hands and legs up get a wheelie bin and cut a hole in the top of the bin. shove him in there with his head sticking out the top and wheel him around the town feeding him piss all night
you can turn your back on a man, but never...ever... turn your back on a drug... especially one that is waving a 9inch hunting knife in your face...
all i wanted to do was cut a little z in your forehead...thats all
i can't drive this weekend... not happy:/
LOL...;)
Dont worry, im on the hunt for some ether...because everyone in Sheppatton loves a drunkard:)
whatever jarrod cops, i want to see pictures!! and don't worry bout melissa. i'm sure she will join in the fun and hold him back for you to shave his head or eyebrows!! btw troy, i'm the overly drunkin sod u met at jarrods 21st with the cef.  ;)
Yeh, yeh i remember...we need "Ben, our spiritual leader" on this journey of indulgent behaviour:)
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
