  • Replies 127
lwells - I can definitely get the power fc pro for your GTR. I will post prices shortly.
HLT4Eva - Ive added you to the list.
rob1981 - Ive added you to the list and PM sent.
:P
WetGTR - PM sent.
lwells - heres some prices.
APEXi Power FC PRO (R32 GTR) - $1090 delivered
APEXi Power FC PRO & Cmmander (R32 GTR) - $1460 delivered
Note - the PRO units are made to order from Japan and will take from 2-6 weeks for delivery.
Thanks for that. Bit more than I want to pay: put me down for a standard R32 GT-R unit.
Lucien.
what is th dif between pro and the one i am geting what is the price dif and the pformance dif and is it worth spending the extra money for 97 r33
It depends on what you want to do with your car.
The power fc pro is designed for drag racing use.
These units have 2 additional functions over the regular units:
1. Ignition cut used for rev limiter - Regular Power FC cut fuel feed when the preset rev limit is reached. At high rpm there is the possibility of knocking when the fuel is cut in high powered cars.
The Power fc Pro cuts ignition at the rev limit to prevent knocking that could potentially destroy the engine.
2. 0km/h rev limiter setting - Allows for the setting for an initial rev limiter that is active whilst the car is not in motion.
This allows for maintaining a rpm level for constant launches.
Similar cost and lead time to the GTR version as mentioned above.
since the other one is gone... when do u need payment by? coz im really broke atm
Close date - 12/07/05
Payment due - 14/07/05
I'll send payment details to all the buyers before the close date.
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
