  • Replies 127
lwells - I can definitely get the power fc pro for your GTR. I will post prices shortly.
HLT4Eva - Ive added you to the list.
rob1981 - Ive added you to the list and PM sent.
:P
WetGTR - PM sent.
lwells - heres some prices.
APEXi Power FC PRO (R32 GTR) - $1090 delivered
APEXi Power FC PRO & Cmmander (R32 GTR) - $1460 delivered
Note - the PRO units are made to order from Japan and will take from 2-6 weeks for delivery.
Thanks for that. Bit more than I want to pay: put me down for a standard R32 GT-R unit.
Lucien.
what is th dif between pro and the one i am geting what is the price dif and the pformance dif and is it worth spending the extra money for 97 r33
It depends on what you want to do with your car.
The power fc pro is designed for drag racing use.
These units have 2 additional functions over the regular units:
1. Ignition cut used for rev limiter - Regular Power FC cut fuel feed when the preset rev limit is reached. At high rpm there is the possibility of knocking when the fuel is cut in high powered cars.
The Power fc Pro cuts ignition at the rev limit to prevent knocking that could potentially destroy the engine.
2. 0km/h rev limiter setting - Allows for the setting for an initial rev limiter that is active whilst the car is not in motion.
This allows for maintaining a rpm level for constant launches.
Similar cost and lead time to the GTR version as mentioned above.
since the other one is gone... when do u need payment by? coz im really broke atm
Close date - 12/07/05
Payment due - 14/07/05
I'll send payment details to all the buyers before the close date.
Guest
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
