maybe also the fact that, most ppl dont seem to want a modded skyline, purely due to knownin its been trashed or ppl just want a fresh start and want to mod their line by themselves... I have seen heaps of really gd bargains, but i believe most people get pushed away, when they see a whole heap of mods been done..
Then again, thats just what I think and i could be wrong..
I find issue with the "modded its been thrashed" sometimes.. well mb not that... the modded its going to **** it ..
Ok, now an exhaust, is probably actually going to reduce the backpressure, probably reducing temperatures at the turbo, and possibly increasing turbo life.
An aftermarket ECU in conjunction with boost controller, if adequately tuned may actually reduce stress on the engine by preventing missfiring, overfueling, etc when the power is raised. Would you rather somebody who had just kept the stock ecu "as is" and tampered with the boost at some point in stupid ways via say a bleed valve (indetectable)?? or somebody who had done it properly??
Now the key point is - how can you really "thrash" a car in Australia's main cities? 60km/hr speed limits, 100km/hr highways, etc.. even if you accelerate as hard as possible at every opportunity, if you "thrashed" the car around, redlined it in every single gear all day every day I doubt you're soon well well over the speed limit. Trashing a skyline is like redlining it to 250km/hr.. Its not even that possible that often!
Now as long as its been adequately tuned, and fluids changed, etc - I don't think there would be much of an issue. These cars were made for a bit of pasting, and that is why the engines are overengineered to take a lot more power, and handle a few stupid things.
Track racers? its hard enough to fill numbers even at your average track day, through so many road users scared to push their cars, blow up an expensive RB26dett, spend the money, etc, etc. Its not a big thing here in Australia. Maybe 1 in 50 skylines here would actually see a racetrack, drift day or official drag strip, if that..
But I am sure it can be disputed of course... and it depends on the level of modifications afterall.
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
