What wires?
I finally got a aftermarket headunit for my 1983 hr30 p.n.v. so I can get away from that awful jap analogue radio that i can only get 3 stations on.
Now, If anyone could help me i'd really appreciate it. I'm after the following info:
1. What Coloured wires are for the factory speaker wires?
2. What Coloured wires are for the Ground and ACC?
If no one can help i guess ill have to go through trial and error with the speaker wires and use the Ciggarette lighter for my power and ACC.
Regards, George
Use a multimeter for the ground and acc...
With the speaker wires.. use a battery.. like an AA battery...
it will pop the speakers and that will show you which speaker the wire belongs to..
Also to find out which wirre is POSITIVE, watch the speaker as it pops. it it pops outwards then the wires are the correct way round on the battery.. whatever wire is on the POSTIVE on the battery is the POSITIVE wire.. :rofl:
Goodluck.
 Share
    • Hi fellow SAU members, I want to put coupe tail lights on my R32 sedan. I have been told it was as easy as changing the boot lid and the tail lights and possibly the rear bar. I have since found out that this is incorrect after buying the lights and boot. The coupe boot dosnt allow the boot to oprn on a sedan and the tail lights won't fit either. Has anyone done this or seen it done and could help me out with some guidance or instructions to get it done.
    • Noice one 👍 I've done a 1:16.300 at Watkins Glen, will keep at it. Still have to knock off half a second at Suzuka in the Roadster
    • Two golds! Struggled to get silver on Gran Valley.
    • Interesting that it has 2 to the USB stick. Are the ones to the USB stick different? Or labelled anything at all? Telstra 4G is Band 28 is the long range one you want, it's 700mHz. I'm trying to do some reading on the Cel-Fi stuff, but I can't find any decent info online that makes me feel comfortable being able to work out the sort of antennas we could get away to swapping it over to. The antennas I'm starting to do some stuff with at work, are a transparent antenna. They're designed to stick onto the window. Which means you wouldn't even have the antenna outside the car. Volkswagen have just started using the exact same types of antennas on some of their new cars (And from the same antenna manufacturer). But, RF stuff is a bit of a dark art some days, and getting it wrong in your car could make for a terrible waste of money trying to swap antennas :S
    • I'm not going to lie Duncan, Saturday and Sunday were pretty rough days. The sort of work I was doing would previously have ended up with me spending about an hour and a half chatting with Neil. Firstly about something I had a question about, and then both of us rambling off on tangents.  I think how Neil did things, and his attitude to getting it done is helping me in part to get this stuff done. Then I can actually do the things I enjoy more easily
