0.5 o/s Forged Pistons, rings and bearings replaced at 70,000 klm, Shot peeneed, knife edge, balanced and nitrided crank, rods shot peened and balanced, tomie rod bolts, ceramic coating to pistons, teflon coated skirts, new timing belt, hi pressure oil and high flow water pump. Rebuild cost $5500 just in parts!
Oil filter, engine, gearbox, Diff oils changed at last service
Kei office front coil overs (fully adjusable with camber plates)
cusco rear coil overs with top hats
cusco front castor rods (tension rod?),
cusco front and rear strut braces
Apexi FMIC intercooler
Turbo extractors (fitted 2 weeks ago cost $400 + fit),
***imoto exhaust, front pipe, de cat pipe,
HKS pod filter
Light weight billett flywheel (installed with engine)
heavy duty clutch (full face installed with engine)
omori Water temp, boost, Oil pressure and oil temp (oil temp fitted but needs to be hooked up) gauges, HKS turbo timer,
Mazdaspeed steering wheel (i dont know why this is fitted but it is)
15'' Volk racing wheels
Endless front and rear pads ($400 per Set)
Braided brake lines (worth $350)
Torsen LSD 4.3:1 Ratio
great body for age apart from Damage. Quoted $480 + Parts (bonnet (about $150), bumper (about $100-150), passenger side guard (about $100) and light ($150-$200) and and paint for repair, crashed on the way to compliance and lost intrest. Hit a power box in industrial area at 40 klm. There would have been less damage but the last owner removed the bumper bar support. Looks worse then really is.
Made 168 kw at the wheels (dyno'd after manifold fitted)
The car is uncomplied and unregistered (just imported), add $1300 For compliance then normal rego and insurance costs.
Strictly no time wasters or Joy riders (for obvious reasons) Heaps of high res pictures available on request
180SX CA18DET (Rebuilt w/ forgies) coilovers Volk Minor dama
Kei office front coil overs (fully adjustable with camber plates)
FGK exhaust, front pipe, de cat pipe,
HKS pod filter
Light weight billet flywheel (installed with engine)
Mazdaspeed steering wheel (i don't know why this is fitted but it is)
great body for age apart from Damage. Quoted $480 + Parts (bonnet (about $150), bumper (about $100-150), passenger side guard (about $100) and light ($150-$200) and and paint for repair, crashed on the way to compliance and lost interest. Hit a power box in industrial area at 40 klm. There would have been less damage but the last owner removed the bumper bar support. Looks worse then really is. Made 158 kw at the wheels (dyno'd after manifold fitted) The car is uncomplied and unregistered (just imported), add $1300 For compliance then normal rego and insurance costs. Strictly no time wasters or Joy riders (for obvious reasons) Heaps of high res pictures available on request
Price $9,200
Kilometres 97,000
Body 2 door Coupe
Colour Metallic Grey
Interior Colour Grey
Transmission 5 speed Manual
Engine 4 cylinder Petrol Turbo 1.8L (1809cc)
$9,200 as is
Located in Sydney, epping area.
Phone only 0403 108 701
    • I keep seeing supercharger kits for these listed on marketplace 😂
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
