Very first pass of the night.
VP103 in the tank, MT ET Streets ready to go, Nitrous jetting set to 'KILL' and a 5500rpm launch then straight into the loud pedal was a recipe for disaster.....or so it seems.
Diff has let go and wont engage under load. Pulling it apart today to have a look just how bad it is. If it hadn't broken it would've been an awesome run. Hooked up harder than ever before and shocked me. My helmet smashed into my chest when the car went from being fully loaded up on the tyres to nothing in about half a second. Ouch! :D
Didn't even make 60'.
HUUUUGGGGEEEE thanks to Stuart from Bezerkly Automotive www.bezerkly.com for bringing the car trailer and tow vehicle up from Wollongong and getting me home before midnite. Awesome effort and greatly appreciated.
Adrian
Bad luck mate. What were you running before that? stock? was it reshimmed? hopefully now you'll run faster by putting power to both wheels with the 1.5way.
Factory Nissan and to the best of my knowledge, it has never been touched but for a change of fluid.
Hopefully I'll come up with something bigger and better for the drag day. Anyone have any ideas that don't cost the earth?
"We have the technology, we can re-build him"
Adrian
    • The easiest option might be to just spray a bunch of fish oil in there.  At least that way you can feel like you've done something while you continue to ignore it
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
