Can anyone tell me if R30/31 front lower control arms are the same . The R30 type have non replacable ball joints and Melbourne is fresh out of new ones . If R31 ones fit it'll give me the option of replaceable ball joints but , the bush to ball joint length needs to be the same and the caster rod drillings as well .
Cheers A .
https://www.sau.com.au/forums/topic/78008-r30r31-front-control-arms/
They're not the same...apart from the pivot bush. I used to make some money on the side converting R30 arms to use a replaceable ball joint (Bluebird), but it was a fair bit of effort for relatively small return plus the demand was also quite small. Not a simple job and requires access to a lathe, mill and MIG or TIG welder.
What SteveL said. The R31 arms are shorter as well.
I will be going down the "modify-the-control-arm" path very shortly. Seeing as it is for my rally car, there will be a bit of cutting, shutting, plating and reinforcing going on there...
Discopotato03, if you have no joy in finding any control arms, I'll see if I can find some newbies for you. I only just got a new pair about 3 weeks ago.
Cheers,
Matty T
While I'm here is there a way to remove the slop in the Idler Arm assembly . Mine is new (whole unit) and it still moves up and down taking the drag link with it and making eratic steering . I have visions of ball race bearings or even a gutted steering box on the other side . I have to say that steering dramas have been the most frustrating part of my time with the DR30 .
Cheers A .
Cheers  A .
Steering mechanism is what really let the R30 down AFAIC......recirc ball box+lots of joints/links+a bit of wear=a car that steers like a boat.
I found that replacing the standard idler arm bushes with polyurethane improved things, but I don't know if you can still get them. Datto 1600's have a similar steering system so might be worth looking at what the guys that use them for rallying do.
Cheers  A .
Disco,I found my old HR30 to be very irratating in the steering area.Part of the reason I didn't put my FJ20 into it.Going even futher back,I had a 180B, (same set up) and I got a whole single piece bush machined up from some type of poly-eurathane (sp) Worked wonders,but the steering box sucks teh ass! :thumbsup:
Hehehe Thats why I am looking into a R31 crossmemeber with rack and pinion steering and making engine mounts from there.
Can anyone else tell me if a r31 cross member fits??? (or else it will be all custom) I want rack and peanut damn it. It's not like everything else in my car isnt custom it just would be nice if something fitted good for a change might have to go to u-pull-it for a measure. :chairshot
Homer,do you even know what rack and pinion steering is? :(
Don't hold your breath on a '31 crossmember fitting in a '30. Ahhhh,so glad all my steering box woes are behind me.
Go the HR31! :) :uh-huh: :D
I asked ghostrider this ages ago to which he replied no the mounting pads are further apart . Also the R31 lower arms are shorter (pivot points different) wich is a disadvantage for camber change .
I was talking to my Nissan rally specialist and he believes its all in the idler arm bushes , even genuine (new) they're too compliant . I'm going to try and machine some bushings up out of a special acetyl material to get firmer ones .
Cheers A .
OHR-30T , thats interesting about the 180B idler arm fix . Did the machinist turn up two taper walled bushes or bore the arm section parallel walled for a cylinderical bush ? Also what material was the bush made of ?
I was under my car yesterday afternoon pulling up and down on the idler arm and watching the nearside wheel toe angle change markedly . This is with a new genuine idler arm assembly (1 month old) , the arm rocks on the tapered bushes which is totally unacceptable . The offside doesn't budge on its end of the drag link because the power steering box and pitman arm are robust and rigid .
It appears that the idler arm vertical movement is the weak part of the system and a workable fix should not be an engineering feat . If I can get my rally specialist interested (very busy ATM) , if enough people are interested he may be persuaded to do a short production run of something that works for an acceptable cost (economies of scale) .
I aim to fix this one way or another otherwise the vehicle is useless to me .
Cheers A .
Disco, it's been that long I can't bloody remember exactly what was done! :P I do remember it was a one piece bush though,so unless it was slotted or something,I'd say the housing was machined parralell? Don't quote me on that though.The bush material was some sort of poly urethane...what ever grade the guy thought was suitable. I thought you were giving up on the FJ,and going with an RB30 hybrid anyway?
OHR-30T yes in time the plan is R32 RB26/31 DET . ATM I'm living with the DR30 (which is OK) and trying to correct any niggly probs . A clean car that responds nicely to driver inputs is a pleasure to drive and sells itself . Also refuse to be beaten by minor technical hitches . The plan for the back is to find its squat height and align the semi trailing arms to have zero toe and zero or just a tiny bit of negative camber .
I want to make the best of what I have and apply the results to later cars with more sophisticated factory suspension . If Fred and the boys made respectable racers out of R30/31's we should be able to make reasonable road cars of them .
Cheers A .
Do any other steering racks/crossmembers fit or be easier to fit into a DR30:confused:(S13, R32).
Are S13 racks rack and pinion?
No, and yes ;)
Disco: Sounds like a plan, but wouldn't the squat height vary depending on how much grip you had at any particular time?
If Fred and the boys made respectable racers out of R30/31's we should be able to make reasonable road cars of them.
Amen brother! :uh-huh: Speaking of such,I've just had poly ethelene bushes for my rear HICAS rams machined up.You should've seen th eold rubber bushes that came out of them! (or lack thereof) :)
Its been said that a couple of cable ties around the rear damper pistons will move up to show squat height when under maximum acceleration or power load . This is where you need neutral camber and toe to put the most rubber on the road ie largest contact patch . Once this is known I suppose enough bags of cement in the boot at aignment time should re create it .
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
