R33 Gtst Sellout Parts Galore!!!!!!!! -=gotta Go=-
If it has had a code in the recent past, the code should still be there waiting to be read.
By thatjawncrazy · Posted
if I find a shop that has an OBD I tool and can connect it to the port - i wonder what the suggested route is for purposely triggering transmission limp mode while i happen to be within driving distance of the shop, and then dropping everything to stop by and have them scan it. so, it would be nice if things worked out that way - but in case they don't, we are back to my original question of "will bad fluid ever trigger limp mode on its own". -
Any chance the zero demand ignition table is messed up? Or possibly the minimum tps for it to engage zero demand?
32010-AA520 - R34 RB25DET manual transmission, you can buy this new. You'll need a pull to push type clutch converter (to use R33 clutch kits), or buy pull-type clutch (R34 clutch). R33 part number if you're lazy: 32010-21U00 Applies: RB25DET.MT.F5; Notes: FS5R30A
