im a bit confused :confused: with filters now i want to keep my orig. air box it seams to be the a good option performance wise ,now so far i am looking at the followin flat panel.
apexi $100
nismo $160
k&n $120
and am wondering witch is better or if they are all the same.
https://www.sau.com.au/forums/topic/78101-air-filter/
I've heard Apexi panels are good. But you're probably better off getting a pod and sealing it while feeding it with a CAI pipe from the front of your car. Will make it much better - power wise and you should get better power economy too. Oh and its all legal! :)
https://www.sau.com.au/forums/topic/78101-air-filter/#findComment-1426609
Cut your airbox and run some CAI piping to it with a KnN hi flow panel filter, will do the trick very well :(
A pod filter with CAI and heat shielding may be slightly better but not noticeably and will cost you alot more than using your existing box and some home modifyin
https://www.sau.com.au/forums/topic/78101-air-filter/#findComment-1429489
apexi  $100
nismo $160
k&n $120
Where are you getting an Apexi Panel Filter for $100.00 ??
Interested as I'm going away from a pod and back to the box.
https://www.sau.com.au/forums/topic/78101-air-filter/#findComment-1440620
Pods are defectable because they're modified equipment.
Their legality has nothing to do with being boxed.
It just needs to be engineered.
https://www.sau.com.au/forums/topic/78101-air-filter/#findComment-1440836
i know im going to get in trouble for this, but ive been wondering for a while....
why not just use the $29 ones from super cheap auto (they look exactly the same, even on close inspection!!)?? (ducks in readyness)
Or a $12.50 original Nissan one...
https://www.sau.com.au/forums/topic/78101-air-filter/#findComment-1441050
  • 3 weeks later...
Hey guys, I'm also wondrin wat i shud do wit me air intake... was originally thinking of just stickin a K&N pod on the end, but am now feeding that wit some cai piping from the front. wud be grately for any pics ppl hav of their setups, or comments.
also, with some of the reading i've been doin, ppl suggest that just getn a good panel filter and puttin it in the stock airbox is good?
https://www.sau.com.au/forums/topic/78101-air-filter/#findComment-1469359
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
