what r the best spark plugs????
NGK BCPR6ES, pretty much what everyone runs, they are cheap and good
Make sure they are the 0.8mm gapped plugs, as I bought some once and found after I installed them it mis-fired, and found that the gaps where set at 1.1mm
I use the NGKs.
Personally I don't see the point in buying iridium or plugs when coppers are absolutely fine and very cheap. The obvious exception is where its a PITA to change the plugs and the longer life of the more expensive plugs is more worthwhile.
LW.
Hey, i had a mech once tell me skylines wont run propperly unless you run platnums. what a scammer! He even made me feel like a twit when i told him not to touch the coppers that were in there (they were only 500kms old)
Sorry to sound like a dope but does the "6" in the code refer to the heat range?
Can you get BCPR5ES if that is the case? A 5 heat range was suggested to cure a bad start when cold....
Dont think you can get them pre gapped they will come 1.1 hence the -11 at the end of the pn. you can get a special gapping tool but i usually just tap on the electrode and check it with feeler gauges till i get it right
Im currently using some OWS Uber Power Twin Irridium's Gapped at about .64
Running a treat... the came gapped at 1.1mm but it was missing under load... :P
need some split fire coils for that :)
either way the OWS's are running really good now. car hasnt missed in ages.
I gapped my BCPR6ES-11s down to 0.8mm. No wonder it was backfiring :) They were still at 1.1mm. Backfire fixed. ALso coated my coilpacks in roof sealant. Works as good as Araldite, temp safe to 150 degrees C and is only 7 bucks.
Car is running mint (touch wood ;) )
 Share
    • Its also very clearly made to take business away from https://theskylineshed.com/ which is legitimate and even has a physical address.
    • The 'About Us' got me ..  I added something to the cart and clicked 'check out' and none of the payment options in the footer (ie those with buyer protection) were available. Stay the hell away from this one.
    • No. Not true for any non-GTR R32. I think even the GTS4 has the GTSt knuckles with eye type lower shock mounts (as opposed to GTR fork lower shock mounts). The only R chassis in which something like the quote claim is true is the R34, on which the turbos have the fork type and the NAs have the eye type. **Edit: Actually I reserve the right to be wrong about the above statement. It might also be true on R33s. My memory on those shitboxen has faded too much.
    • It's a scam. It has all the telltale signs: - The "business" doesn't have a physical address or really any kind of information listed - It's using a generic online store website template - The prices are ridiculously reduced. To good to be true cheap - Everything is in stock and can be ordered in any possible combination   I've seen a few of these for other products as well. Things like sunglasses for example. I'd say stay away from it! And maybe reach out to the real theskylineshed and let them know this exists. I doubt there is much they can do about it, but still.   I don't know if they would actually take your money if you ordered something. Or whether it is just for collecting credit card details to scam otherwise. I'm not game or stupid enough to try it.
    • Hi guys has anyone ever bought from this website theskylineshed.shop?? Not theskylineshed.com as I’m aware there is 2 similar but different sites.     has anyone had any issues with theskylineshed.shop???
