Boyz, im just about to install Apexi dual chamber Bloff off valve on my 94 R33.
On the stock BOV - pictured below , what do you do with the big black tube that was attached to the STOCK BOV, as the new apexi bov only has the spot for the vaccume line ?
Stock BOV
Apexi Twin Chamber
Do u just block it off ? or does it have to be connected somewhere else.
Any help....thanks...
https://www.sau.com.au/forums/topic/78161-bov-install-quick-question/
the big black tube is the "PLUMBACK" line.
sine the apexi is a atmo venting bov.. you simply block the big black plumback line.
take the rubber hose off the plumback line and put a coke bottle cap over the now open metal plumback line.
clamp it on there using the hose clamp off the rubber hose.
get me?
yep.
block off the rubber hose from the stock bov
leave that looped hose there.
the vacuum line from the stock bov goes to the top of the apexi one.
BEUTIFUL - thats simple enough. Block the black PLUMB BACK hose and take the vaccume line from the stock bov and connect it to the apex one.
The bov already has the flange adapter to bolt on as u can see. so it should be a 5 min install.
Thanks for your help man.
