Aahhggg!!! Help!!!
Hey guys i really need your info on this issue
I just got rego for my R33 and they said i have to go to a 3rd party rta inspection??
i got lowered springs (2.75 r, 2.5 f)
17inch wheels (9in f, 10in r)
bov
pod
cat catback
strut brace
dual stage boost
Now my thoughts are to replace the bov with stock,same as airbox, take off strut brace, leave dual stage
cut an inch off the front bar as it doesn't sit that low now with the 17's but im afraid ;)
Is there anyone out of this!??
HEELLPPP!!!
DOnnie
https://www.sau.com.au/forums/topic/7817-aahhggg-help/
Donnie inspection required means any pink slip place ie your local servo just has to check your lights, tyres, engine and vin numbers etc thats all.
unless you drive in with a shower of sparks due to lowering your car 7 inches with a hacksaw and you have removed both your headlights for better air induction and maybe tinted your windscreen 5% - i cant see you having a problem ;)
https://www.sau.com.au/forums/topic/7817-aahhggg-help/#findComment-114388
Only the RTA can do a 3rd tier inspection. XCUZME and DR GTR is right, they don't care about mods, it's just mostly checking that it isn't a rebirth. I think there are only 4 inspection stations in NSW.
You should pass easily.
You might need a blue slip aswell. Special price for imports, $100+!
https://www.sau.com.au/forums/topic/7817-aahhggg-help/#findComment-114813
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
