  • Replies 117
You think you got the oldest icq number???
Try this out:
ICQ 873042 (hardly used, but I BEAT YOU exstatic!!!) :bahaha:
MSN [email protected]
Feel free to add me...
Rianto
Originally posted by ex-static
yea trillian rocks :)
anyway...
12886924 (wow ive got the oldest icq number out of all of your.. gah.. im a nerd :))
[email protected]
https://www.sau.com.au/forums/topic/7820-icq-msn/page/3/#findComment-131573
In fact I just gava Gerald a call this morning..... and apparently it could finish tomorrow or Thursday... they're waiting for the car back from an auto electrician to bypass the neutral safety starter (otherwise car won't start as it thinks still in gear 'D').
Anyway I can't make it on Wed, so if car is finished, I hope I can drive it home on Thursday. But Gerald still needs to replace my brake pads and suspension bushes.
I dropped the car in last week's Monday evening, so considering the progress it's pretty quick!
https://www.sau.com.au/forums/topic/7820-icq-msn/page/3/#findComment-134072
  • 3 weeks later...
Originally posted by predator666
yep, and in fact Yahoo and IRC. So basically you through one client access all these networks through your normal logins to speak to your friends, etc. Its very nice. Give it a try and see.
does that mean i can access irc from work
cause ive tried to dl it and it wont connect
https://www.sau.com.au/forums/topic/7820-icq-msn/page/3/#findComment-209333
    • I bought one for a 32 and it was junk, found its way into the bin
    • have a look at the other 2 stock rubber strips marked in blue. As you can see, they press against the cooling panel and leave marks. If the cooling unit panel isn’t there, the strip press against nothing therefore have no use. So Nissan was thinking ahead when they manufactured the cars, as they must’ve known people will install the panels in the future. Otherwise think about it, why else would they be there? Therefore that in itself directly infers that cooling panels do something. It might be to stop water and stop some air from going above the cooling panel so more of the air can be redirected between the cooling panel and the front bar. I tried to take a pic of it while the bonnet was closed but u can’t see shit in the photo
    • @DraftySquash @Duncan i misspoke, or this might be the other way. someone sent me a low res pic of it on It might completely close off the gap in red like in the second pic (second pic has gktech cooling panel on) .The 3 holes are for the plastic rivets used to secure down the front bar. The outer holes on the radiator side go underneath the condenser brackets If thats the case then there’s going to be no air going in through the grill between the bonnet and the bar for the radiator and condenser. Isn’t that bad? I mean less airflow to the radiator and condenser is all I’m saying
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
