R30
Hey everyone,
First time user, so be nice..lol
I have a R30 that sat in the backyard for a few months. I was waiting to get my liscence. Anyway, I wanted to see if she would start first go, so I got petrol for her and a new battery and she started first go. woo-hoo. On the day I went to go for a roadworthy test to get registered, she did not start at all. A mate of mine checked the battery, oil, petrol 1/4 tank, spark plugs, etc. Nothing wrong :confused: . The only thing that I noticed that was not the same, was the hummming from the back. Now I have no idea where the pump is located in this car, is it in the tank, or outside of the tank. Any help or feedback would be greatly appreciated.
Thanks :thumbsup:
fuel pump not working?
its an external pump, pretty much under the right rear passenger door, stick your head under there and check for a mount holding something the size of a small deodorant can.
if its not "buzzing" with the keys in the "on" pos, try kicking the motor over and tapping on the fuel pump at the same time....worked for me. and i dont mean just knock on the pump with your knuckles, tap it wif a friggin hammer or something.....you'll look like a hick but if it is the fuel pump, she'll fire over.
:Pimp2: :Pimp2:
I'll tell you now that it's the first sign the pump is about to die proper. Mine did yesterday. Managed to replace it with one I originally got to run the L20ET in my Z.
Nissan want you to mortgage your house for a replacement. I reckon they are about the same size as a VL Turbo pump.
if anything the VL turbo pump will be better for it because it is a higher flow pump and there cheap as to get anyway (cheap...well, relative to the nissan ones)
Ummm it might not be the pump guys (but i dunno if its carbed or efi), this happend to my car and was off the road for 3 months while i was diagnosing the problem and trying to get it started.
The problem was the Fuel Pump Computer under the rear parcel tray. Try replacing that and see if you have any luck. Started first time for me after i replaced that.
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
