This is confusing the hell outta me :confused:
Ive looked at the firewall on my skyline and there doesn't seem to be anywhere to run some cable through....do I have to drill a new whole?
I don't really wanna drill a new whole incase there is something behind the sopt I drill and I puncture something....
I need to run some 4 gauge cable from my battery under the bonnet all the way to the boot, I have already run all other cables to amps, deck, speakers etc...now it just needs POWA :uh-huh:
........help!
https://www.sau.com.au/forums/topic/78238-running-cable-through-r32-firewall/
there are some rubber/foam grommetsthe go thru if your looking from the inside they are right up underneath the dash easier to get to them from the engine bay they are kind of triangular in shape just slip youe wire through there. if you still cant find it try tracing your other wires in the engine bay through the firewall and slipping it along side them. but there is definitly a grommet there that you can remove to feed it through
What you need to do is
1. In the car on the drivers side take of the kick panel (right foot side when sitting in the car) with this off you should be able to see the firewall and in the corner a large rubber grommet.
2. Jack the car up, front driver’s side wheel, take the wheel off. once the wheel is off you need to remove the plastic cover in the wheel arch. don’t take it all off as there are like 500 screws just what is nessacery to pull part of it down. ps. you might want to put some car stands to hold the car up instead of leaving the car on the jack
3. standing at the side of the car where you took the wheel off take the power cable and push it through the guard there should be an opening near brake booster side of the guard (back end of the guard behind the strut tower) just feel around under the guard to find the opening. once you have found the opening, push it through the cable should know be in the wheel arc where you pulled the wheel cover down. put your hand up there and find the cable and then push the cable trough the grommet you should be able to feel it at the back of the guard
4. the cable should now be inside the car.
if you have any probs i can pm you my number and a can talk you through it
if you need any pics i can get you some
Good luck
I found this:
http://www.skylinesaustralia.com/forums/sh...hrough+firewall
describing pretty much what mr 32 described, thanks all, will see if I can find that hole....is it easy to do with the wheel on?
you cant do it with the wheel on as you cant take the inner plastic wheel arc cover off. if anything it is easyer with the wheel off
There is no need to go under the car or wheel arch at all. The easiest way to run cables in the R32 is down the drivers side from inside the engine bay.
There is a triangular shaped grommet in the inner guard behind the shocktower beside the brake booster.
When you remove the triangular grommet you will see a large round grommet in the firewall
directly behind it. From inside the car this grommet is located high above the accelerater pedal.
Remove the driver's kickpanel for better access.
Poke a screwdriver through the round grommet, from inside the car, into the engine bay far enough so that you can use electrical tape to tie the cable to the tip of the screwdriver.
If the cable is thick a bit of rubber grease will help to ease the screwdriver and cable back through the grommet.
Feed enough cable through to reach the amp and run the cable under the edge of the carpet where the sill meets the floorpan.
where would that cable some out in the engine bay?, under the brake booster?, I can't see any grommet from the top of the booster!, unless I am just blind
hmmm. now thats my problem...I already have speaker cable, remote wire cable and 2 RCA's running down the drivers side, so I am gunna go over the back of the dash and run it along the passengers side....6m should get that done right?
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
