Ok, now i have finialy installed the rb turbo i got, just rebuild 3000K before i got it, And also installed a new o2 in a factory dump pipe. Now for you in the know and need to know. this is what is required.
The rb turbo is a direct bolt on, Hence it uses the T3 flange, Now if you use the rb20det dumppipe be prepared to grind part of you block off near the end of the dump pipe as it doesnt clear.
The Top oil feed line bolts right on, No problems, The oil return line at the bottom needs to be "adjusted" to fit the diffrent angle of the exit on the rb turbo. So heating and bending it to the right angle works.
the hard bit. : outlet pipe, This require many hours of removing and installing the intake manifold to get the right angle to cleer it, This is the hard bit........ Spend time on this.
other than that, its all straight forward. Im running 9psi and its QUICK compared to before with 12-15psi, my turbo had so much play and wined like a bitch and had bits missing out of the compressor wheel :(.
9 hours work, not so great
https://www.sau.com.au/forums/topic/78281-updated-rb20det-bb-turbo-upgrade/
Yeah. you do need the rb dump pipe or a aftermarket version. Power is great now, Smooth strong heaps of torque. Its now drives like a Rb, pitty tho no more 80's turbo lag kick. ;)
Im only running 9psi but it definitly has more power than my other running 8psi which i did 109rwkw on. im thinking of around 115rwkw easly on 9psi :)
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
