Hi ppls,
Bl4ck32 and I have an AP Engineering R32 RB20DET PowerFC.
We have ran in to issues (Bl4ck32 Specifically) where the load points are being maxed out preventing more boost and power.
We are both running RB30DET's, using the R32 RB25 head and RB30 bottom end.
I am making 176rwkw and Bl4ck32 is making 200rwkw.
I use load point 19 to make this powe rand Bl4ck32 uses load point 20.
The problem is the PowerFC appears to have ran out of load points. :rofl:
I have replaced my stock airflow meter with a Z32 item, it didn't change the load point used, only the voltage per load point.
i.e The Z32 AFM it now peaks at 4v (thats load point 19) vs the rb20 AFM at 4.9v (that was also at load point 19).
Bl4ck32 is using a Q45 AFM. Same thing, only voltage has changed not the load point used.
So.. The larger (not literally) AFM doesn't reduce the load point used, what can I and Bl4ck32 do now?
What load points are some of you ppls with PFC's using at WOT and what power are you making?
Any tuners out there care to shed any light on our brick wall?
Our Tuner is contacting Apexi to find out what he can do, he has used the Datalogit software previously and said it cannot change the load point scale.
I've attached a pic of the AFM Menu that is located within the Settings menu.
All of the AFM menu AFM items contain the same values.
I am thinking *hoping* this 'may' change the load points used if the 3.84-5.12v is changed from say 100% to 80%??
Similiar to the way a SAFC works.
https://www.sau.com.au/forums/topic/78309-powerfc-ran-out-of-load-points/
He said that it cannot change the load point scale, or that it needs some correction added to one of the tables.....me cant remember exaclty :rofl:
The tuner has no issues making 200+rwkw with other rb20's and their PFC's (Chris32) as higher load points at higher rpm = over 200rwkw.
However, I think it does come down to his lack of experience with the rb20 pfc. Generally speaking he does a good job tuning and tunes safe, not to mention he charges bugger all.
The only other tuning shop I would touch down this way want $600 (Tilbrooks).
Others have a reputation of breaking things and or simply not giving a good tune via the PFC.
It appears RB25 pfc's are calibrated differently as at wot and 200rwkw or so they are only hitting load point 15 max. So obviously a lot of head room.
Can ppls check out their Airflow menu? :rofl:
mine goes up to load point 16 or 17 on 9psi - RB30DET with 25 head in r33 with r33 pfc. Does this mean i will have this problem when i finally want to run bigger injectors for bigger boost ? they are running at 90% + atm and im only running stock injectors
interesting...
Mine gets up to load point 16/17, somtimes 18
I wired in the Z32 and selected the Z32 AFM option, otherwise it wouldn't run at all with normal AFM selected
Could it be becasue the AP PFC uses a GTR PFC, and being configured for only the one AFM its using more of the map than it would with 2 AFM's?
I remember in a old Zoom mag they where talking about the fc-logit software being able to extend the map in regards to RPM, but I dont remember it mentioning load
Maybe SK could shed more light, as he runs FC-logit and the RB20 PFC on his R32 RB30 setup doesn't he?
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
