Hi guys, on the Datalogit Settings, Page 3 there is configurable table for the 20 map reference points for RPM and the 20 map reference points for Airflow.
The default RPM reference points are in 400 rpm increments from 400 rpm to 8,000 rpm.
The default Airflow reference points are 1446 (load point 2) increasing by 482 up to load point 10 then 964 from load point 10 to load point 15 then 1928 from load point 15 to load point 20. This is determined by the Air Flow Curves (AFM voltage ramp table) which is also on Settings Page 3
Hope that was of some help :D
sydneykid - Looking at the screenshot are all the white cells user definable? If they are then it certainly looks like fc-datalogit might be the only way around it??
Yep, the whites are input cells.:)
Hope that was of some help :)
That looks interesting, SK, so to get more load points out of the PFC, which values need to be changed?
I don't believe it's a matter of getting more load points, but taking the 20 you have and "stretching" them out, by increasing the "distance" between points on the AFM axis of your map.
I doubt you need to alter all of them, perhaps the top 5, obviously once something as fundamental the "scale" on you map changes the associated fueling values will need to change also.
I hope i made some sense there, if not, ignore me and wait for SK to ride to the rescue! :)
Hi SK,
After a little investigating it appears the rb20's airflow value at load point 20 is roughly the same as the rb25's airflow value at load point 15.
Oosh, You are spot on, all it does is reduce the resolution, the rb20 map reference with the rb30 is fairly usless as to use load points 5-12 you really have to concentrate to only ever so slightly touch the accelerator.
Bigger motor drawing more air the 2.5ltr reference map suits it much better. :mad:
I've stumbled upon an interestering airflow vs horsepower relation. :mad:
After using the rb25det reference map, the airflow required to make ~200rwkw now uses load point 15-16, previously with the rb20det reference map it was maxing out at load point 20 to make the same power.
Calcs.. It appears that the rb25det reference map has been scaled enough to support ~325rwkw of power on the same dyno and peak RPM as I and Bl4ck32 use.
I find it interesting that I am making ~176rwkw and using load points 18-19, both Bl4ck32's and my power figure is supported by the calc. :lock:
Obviously an rb20det, rb25det or rb26dett may make use of the air supplied a little better or worse, the power figure as a result 'should' vary with different motors and RPM!
Now to find some one that knows the power they make at approx 5000rpm with a PowerFC and see if the calc can 'predict' the load point they will use. :D
If it appears to be fairly accurate, we will be able to weed out those bodged dyno power figures. :D
I haven't really thought about rpm at this stage, I have no idea how it scales its airflow/loadpoints as rpm increases, or if it does at all.
My map trace is horizontal, from 2000rpm it drops to load point 18-19 then sits there all the way to peak power.
As an engine increases RPM its supposed to increases its airflow requirement. :confused:
Just to note, I noticed for example.
A load is placed upon the motor that is inbetween two airflow values. The PFC will do a linear (I assume) calc and determine the value to use for that load.
So providing airflow and ignition timing required is linear between the two load points the pfc will do a pretty damn good job working out the optimal value.
It will only do this where ignition timing or fuel has different values between load point cells.
Hope that makes sense. :mad:
Cubes , have been very interested in this topic . Is there an Apexi PFC for the VG30DET or VG30DETT ? If so it would be interesting to know their reference tables particularly as the airflow would be based around 3 litres .
Also probably impossible but are Z32 ECU's electrically similar to R32's ?
Cheers Adrian .
I've stumbled upon an interestering airflow vs horsepower relation. :D
If it appears to be fairly accurate, we will be able to weed out those bodged dyno power figures. ;)
Interesting, ultimately the engines power would depend on its VE at the various airlfow rates. That can vary by 15% or so at numerous RPM's.
One thing I would add is that the RB25DET AFM (PFC default) is set for 5.1 volts at 10860, which is around 170 rwkw. Yet the load point mapping goes to 21213, this means 5.1 volts (the AFM maximum) of 10860 is around load point 14/15. So a standard RB25DET AFM could never show more than load point 14/15.
You are at load point 18/19, but I can't remember what AFM you have?:mad:
Sounds fairly spot on SK, I was very close to 5v on the std RB20DET afm (which actually was a R33 S1 AFM) before the tune so obviously a few more rev's I may have seen it hitting 5v or slightly over.
I made sure before the tune I wired in the Z32 AFM, it has hit a highest of 4.1v on Load point 18/19.
Where did you grab the R33's Airflow airflow value at 5.1v?
Going by the table below (taken from FC_Pro Apexi Software) R32/R33 at 5.1v has an airflow value of 4423. ;)
It doesn't make sense. Especially when you look the Z32 apparently has a higher airflow per voltage than the VH41?!?!
Discopotato,
The airflow reference map from a VG30 would be very interestering to see.
It appears the FC-Logit doesn't do one for the VG30 nor does the Apexi FC Pro Software.
Both softwares do one for the 2JZGTE, might see if I can grab it from the FC Pro Software.
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
