Hi guys, on the Datalogit Settings, Page 3 there is configurable table for the 20 map reference points for RPM and the 20 map reference points for Airflow.
The default RPM reference points are in 400 rpm increments from 400 rpm to 8,000 rpm.
The default Airflow reference points are 1446 (load point 2) increasing by 482 up to load point 10 then 964 from load point 10 to load point 15 then 1928 from load point 15 to load point 20. This is determined by the Air Flow Curves (AFM voltage ramp table) which is also on Settings Page 3
Hope that was of some help :D
sydneykid - Looking at the screenshot are all the white cells user definable? If they are then it certainly looks like fc-datalogit might be the only way around it??
Yep, the whites are input cells.:)
Hope that was of some help :)
That looks interesting, SK, so to get more load points out of the PFC, which values need to be changed?
I don't believe it's a matter of getting more load points, but taking the 20 you have and "stretching" them out, by increasing the "distance" between points on the AFM axis of your map.
I doubt you need to alter all of them, perhaps the top 5, obviously once something as fundamental the "scale" on you map changes the associated fueling values will need to change also.
I hope i made some sense there, if not, ignore me and wait for SK to ride to the rescue! :)
Hi SK,
After a little investigating it appears the rb20's airflow value at load point 20 is roughly the same as the rb25's airflow value at load point 15.
Oosh, You are spot on, all it does is reduce the resolution, the rb20 map reference with the rb30 is fairly usless as to use load points 5-12 you really have to concentrate to only ever so slightly touch the accelerator.
Bigger motor drawing more air the 2.5ltr reference map suits it much better. :mad:
I've stumbled upon an interestering airflow vs horsepower relation. :mad:
After using the rb25det reference map, the airflow required to make ~200rwkw now uses load point 15-16, previously with the rb20det reference map it was maxing out at load point 20 to make the same power.
Calcs.. It appears that the rb25det reference map has been scaled enough to support ~325rwkw of power on the same dyno and peak RPM as I and Bl4ck32 use.
I find it interesting that I am making ~176rwkw and using load points 18-19, both Bl4ck32's and my power figure is supported by the calc. :lock:
Obviously an rb20det, rb25det or rb26dett may make use of the air supplied a little better or worse, the power figure as a result 'should' vary with different motors and RPM!
Now to find some one that knows the power they make at approx 5000rpm with a PowerFC and see if the calc can 'predict' the load point they will use. :D
If it appears to be fairly accurate, we will be able to weed out those bodged dyno power figures. :D
I haven't really thought about rpm at this stage, I have no idea how it scales its airflow/loadpoints as rpm increases, or if it does at all.
My map trace is horizontal, from 2000rpm it drops to load point 18-19 then sits there all the way to peak power.
As an engine increases RPM its supposed to increases its airflow requirement. :confused:
Just to note, I noticed for example.
A load is placed upon the motor that is inbetween two airflow values. The PFC will do a linear (I assume) calc and determine the value to use for that load.
So providing airflow and ignition timing required is linear between the two load points the pfc will do a pretty damn good job working out the optimal value.
It will only do this where ignition timing or fuel has different values between load point cells.
Hope that makes sense. :mad:
Cubes , have been very interested in this topic . Is there an Apexi PFC for the VG30DET or VG30DETT ? If so it would be interesting to know their reference tables particularly as the airflow would be based around 3 litres .
Also probably impossible but are Z32 ECU's electrically similar to R32's ?
Cheers Adrian .
I've stumbled upon an interestering airflow vs horsepower relation. :D
If it appears to be fairly accurate, we will be able to weed out those bodged dyno power figures. ;)
Interesting, ultimately the engines power would depend on its VE at the various airlfow rates. That can vary by 15% or so at numerous RPM's.
One thing I would add is that the RB25DET AFM (PFC default) is set for 5.1 volts at 10860, which is around 170 rwkw. Yet the load point mapping goes to 21213, this means 5.1 volts (the AFM maximum) of 10860 is around load point 14/15. So a standard RB25DET AFM could never show more than load point 14/15.
You are at load point 18/19, but I can't remember what AFM you have?:mad:
Sounds fairly spot on SK, I was very close to 5v on the std RB20DET afm (which actually was a R33 S1 AFM) before the tune so obviously a few more rev's I may have seen it hitting 5v or slightly over.
I made sure before the tune I wired in the Z32 AFM, it has hit a highest of 4.1v on Load point 18/19.
Where did you grab the R33's Airflow airflow value at 5.1v?
Going by the table below (taken from FC_Pro Apexi Software) R32/R33 at 5.1v has an airflow value of 4423. ;)
It doesn't make sense. Especially when you look the Z32 apparently has a higher airflow per voltage than the VH41?!?!
Discopotato,
The airflow reference map from a VG30 would be very interestering to see.
It appears the FC-Logit doesn't do one for the VG30 nor does the Apexi FC Pro Software.
Both softwares do one for the 2JZGTE, might see if I can grab it from the FC Pro Software.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
