Hey all,
Has anybody seen tail lights like this around, any idea where they might have originated from?
I've just bought this car and I'm not 100% sure I'm keen on how the rear-end looks at the moment... let me know what you think.
I would love to get one of the illuminated "Skyline" panels, so if anyone could tell me where to get them i'd appreciate it.
https://www.sau.com.au/forums/topic/7832-r33-tail-lights/
Guest Boxhead
Originally posted by Stoffle
Hey all,
i dont know about where to get them but i rekon if anyone did know where, they would keep it a secret, coz the red afterburners are the trade mark of the skyline...
https://www.sau.com.au/forums/topic/7832-r33-tail-lights/#findComment-114543
Some bodgey Japense bastard had cut the wires on mine so that only the outside two tail lights illuminated.
All 4 would light up for the brakes though.
It was quite cool as no one could pick mine as a Skyline from a distance.
I have since re wired it so that I have the trademark 4 stove plates.
I couldn't bare bieng different, but I think clear is cool
https://www.sau.com.au/forums/topic/7832-r33-tail-lights/#findComment-115532
I probably would've liked that... i kinda dont mind the R32s with the single light kit (so they lose the inner afterburner) but i think that's just because i dont like the 32 lights anyway... the rectangular indicators...
Before I bought the 33 I thought that the inner circles of the taillights were actually lights not just reflectors, I was going to make the outer circles into indicators... so much for that idea...
https://www.sau.com.au/forums/topic/7832-r33-tail-lights/#findComment-115841
Originally posted by darK
that would have been a excellent idea stoffle...
it would have looked pretty nice...
maybe its possible to make the (now.. stay with me here...)
the 2 outer parts of the inner lights into brake lights.. and the 2 outer parts of the outer lights the brake lights.. or vice versa... something like that? would that be possible?
You lost me... :confused:
https://www.sau.com.au/forums/topic/7832-r33-tail-lights/#findComment-118236
We'll I've decided I'm gonna give it a go... make the outer afterburners indicators, the inner ones brake/tail lights... i might make the standard rectangular indicators into brake lights or something too if i can find one of those illuminated 'skyline' panels (apprently they're actually a factory option?). I gather though that this might cause some problems with the boys in blue??
Shouldnt be too difficult though as all of my rear lights have clear lenses... so it'll just be a case of getting the coloured bulbs as Mud said.
https://www.sau.com.au/forums/topic/7832-r33-tail-lights/#findComment-118383
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
