Originally posted by Mud
Some bodgey Japense bastard had cut the wires on mine so that only the outside two tail lights illuminated.
All 4 would light up for the brakes though.
It was quite cool as no one could pick mine as a Skyline from a distance.
I have since re wired it so that I have the trademark 4 stove plates.
I couldn't bare bieng different, but I think clear is cool
LOL They do that for compliancing. Australian ADR only allow for one break light per side.
Yeah just wire it back up when your ready and away you go, hehehe
quote'They do that for compliancing. Australian ADR only allow for one break light per side. 'quote
i have been working in the import market for over 7 years. And i have never see this done for that reson. But some compliancing company's black out s13 corner light's and put in guard repeters, and some don't. I am in QLD but that should not make a diff to ADR's
Well all this talk of changing taillights on my black car there is pointless now, as I've decided to buy a winered r33, as the black car was apparently going to take quite a long time to get over here.
The new car is spotless inside and out (except for steering wheel is worn, it came with a pretty floral cover but i decided that it wasnt required)
it's 1994 m-spec with the only mod being a 3.5" kakimoto exhaust... i can pick it up on tuesday ... yay (now i gotta get the "R33" plates changed to red)
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
