i was in the process of ripping apart the rb26 when i cam accross a set of vacumm lines that come from the stock actuators on turbos run around the back of block go into a t valve. From there they both run to a PCM Valve. I am not running the stock twins and have converted to a single. Will i need these lines and this PCM Valve or can i completly remove it
any information that anyone has please let me know
Thanks
https://www.sau.com.au/forums/topic/78329-pcm-valve/
  • 13 years later...
Thanks
did u find out ? i want to remove mine as well
https://www.sau.com.au/forums/topic/78329-pcm-valve/#findComment-7907387
6 hours ago, Slap said:
Yeah found that.. but I’m not sure
where I can remove or block
those lines so the manifold doesn’t
vent to atmosphere ..
https://www.sau.com.au/forums/topic/78329-pcm-valve/#findComment-7907498
