I went out for a spin last night, everything was running sweet for half an hour or so untill all of a sudden the car started missing under load, basically as soon as it makes more than 4psi. It was like someone flicked a switch!
I have read thousands of posts about plugs and coils but i'm not sure this is the same thing.
The car is a R33 Series 1. Stock except for:-
3 inch turbo back exhaust
K&N filter eliment
Boost solinoid set to permanent high boost
All mods have done over 20000KM
The problem
missing when under load/boosting more than 4psi(approx),
runs smooth off boost, even at higher revs as long as it's not boosting
Does a coil pack or plugs go off this quickly or should i be looking for something else. It was running fine, then three seconds later it was running like shit!
Any help very much appreciated
https://www.sau.com.au/forums/topic/78337-mis-under-load/
will be pulling the plugs later today. i have platnums in there , if i think one could possibly be a little fowled i'll put a brand new set of coppers in.
the boost is standard, i have just hardwired the standard high/low solenoid.
as for the revs, it has an occasional mis around 3000 and it's really bad around 4000.
i tried driving through the miss but it is the same up higher
https://www.sau.com.au/forums/topic/78337-mis-under-load/#findComment-1430515
ok, put new plugs in tonight, the missing isn't as bad now.
i think this could be due to me regapping the new plugs down to .8, the old ones were 1.1. So it looks like it was the coils after all.
I managed to pick up a bit more boost too, i must have sealed a leak when i was re-attaching everything.
Does anyone know where to get some spitfire coils in Australia at a reasonable price? I know there is a group buy but my car is a daily driver and i don't want to have to wait that long.
https://www.sau.com.au/forums/topic/78337-mis-under-load/#findComment-1433515
A friend of my had problems with the colis in his getz (not a skyline but still has spark plugs). They were leaking bad (big sparks from the coils at night). He took it to the dealer and they were able to read the voltage off each coil.
But if you want to replace one coil pack you might aswell do all of them otherwise the problem will repeat itself down the track.
So as sumo said check out that other thread
https://www.sau.com.au/forums/topic/78337-mis-under-load/#findComment-1436230
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
