It is necessary. metal head gaskets require a very low Ra (roughness average) finish to seal properly as there is very little give in the gasket to conform to the head. The head also needs to be dead flat. Most machine shops use PCD cutters in their surface mills now to get the finish fine enough to seal properly with these gaskets. Makes sure the block is spotless as well. It doesnt hurt to use an oil stone to finish the block to remove any small high spots, you find the block does pull up a little around the head bolt holes.
It should cost less that $100 to have it machined as long as you remove the manifolds and cams/buckets/shims. Make sure you keep the buckets and shims in order so you can put them back on the same valve.
This engine was totally stock when I pulled it apart, so don't think it's seen massive boost and all that sort of thing.
How can I tell if it's perfect flat, as to be honest I don't really want to have to go to the huge trouble (and cost!) of having the whole head pulled apart and reassembled!
Can you access to a really straight edge adge and feeler gauges
if so lay the straight edge accross the head or block and see if the feeler gauge ( 1 or 2 thou) will go under the straight edge anywhere on the head
simple really
pete
