WHEELS IN STOCK!!!! NEW NEW NEW
Here's a list of the wheels and available sizes.
These are available with or without tyres as of July 1st.
PRICES AVAILABLE NOW!
****NOTE**** Offsets to suit most popular vehicle makes and models.
Some wheels listed can be ordered in staggered sizes. Please take note of the size range listed for each wheel model.
GT-R Specific wheels are in the Konig range.
This is what's in stock at the moment. No waiting!!
PRICING AS FOLLOWS
DR range including RSGT
17" $1040 inc tyres $1600
18" $1400 inc tyres $2120
19" $1800 inc tyres $3000
Konig range
17" $1420 inc tyres $1980
18" $1880 inc tyres $2600
19" $2600 inc tyres $3800
20" $2860 inc tyres $4200
Katana range
17" $1120 inc tyres $1680
18" $1480 inc tyres $2200
19" $1880 inc tyres $3080
Why such skinny wheels Charles? The Koenigs are about the only ones that are 8inch or wider. I thought you would have got wider wheels.
I'll be keeping an eye out to see what your prices are tho, especially on the RS-GTs, but I don't know what kind of tyres I can get onto a 17x7inch rim.
7inch is 177.8mm, so I'm thinking around 225 might be around the max, but I'm not sure.
If you've got anything else available soon, new or used, with or without tyres, for R32 GTR, let me know (She gets into Sydney this week)
The sizes listed with every picture are the only sizes the manufacturers make.
I'm also looking into other models that will be more Skyline GTS and GT-R specific.
These however are what i have in stock at the moment.
Prices available and tyre package listings from the first of July (new financial year)
Thanks for being patient guys!!
Charles.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
