Unfortunately I threw out the old sets I had to compare, but never bothered to compare as the GTR has Brembo on a larger rotor and the GTSt has Sumitomo which are a significantly shape.
I would seriously doubt they would fit so maybe send tham back. What did they cost, if you don't mind me asking?
https://www.sau.com.au/forums/topic/78352-gtr-pads-on-25t/#findComment-1430565
$150nz inc brake fluid, hey would you be willing to ship the hicas lock-kit into newzealand if i paid?
Can you PM me details of where you ordered the brake pads.
$150NZ seems like a good price - what type/model of Endless pads where they?
Thanks!
PEAR
https://www.sau.com.au/forums/topic/78352-gtr-pads-on-25t/#findComment-1457090
Hang on :runs to garage:
Yep, Brembo's and despite the sticker it ain't a VSpec (goddam sticker ricers). The R34 came with the same spec Brembos as well.
Don't take it to heart, I was just having a lend but hey, you get to learn something, and it's free :cheers:
https://www.sau.com.au/forums/topic/78352-gtr-pads-on-25t/#findComment-1458466
on the topic of gtr pads - i have a set of 32 GTR and have put them into my 32 GTST (type-m) calipers. They fit into the calipers, and align up with the rotor surface quite nicely.
Anything else I should be looking out for? Has anyone tried this?
p.s - they are not on the car yet... wanted to make sure.
Thanks
Eug
https://www.sau.com.au/forums/topic/78352-gtr-pads-on-25t/#findComment-1467045
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
    • These arrived today! Sadly I'm going to probably be smart and enjoy the car as is over the summer/sunny period and save the ~2 weeks downtime it'd take to swap the heads over and tune later in the year. Maybe. It's going to be pretty damn tempting seeing these bolt on funs just sitting in storage when they're ready to go. There's a non-zero chance I end up @The Bogan'ing it.
    • MZ11 Toyota Soarer in Iwata, Higashi Osaka
