Went out and got some nighttime pics...
These were done with 'shutter priority' with shutter speeds ranging from 5 secs to 20 secs with an aperture of f4.5 or there abouts. I wanted to play with the white balance and other little things that the Nikon D70 has in it's menu's, but the guys at my location turned the lights off on me... thats why theres only one kinda dark image with the pretty little lights on the trees :boohoo:
https://www.sau.com.au/forums/topic/78365-went-out-and-got-some-nighttime-pics/
A D70??? You bastard! :Pimp2:
Though the last one was probably the best.
I'm getting a serious camera myself though the nightshots will not be as good. What do you think of Konica Minolta A200? Or the Pentax isx*d (forgot the name).
The above cameras will do the job,but Nikon and Canon is slr s.
Nikon have been running some good value packs with the D70 to make way for the D70s.I myself have got the D70.
Check:http://www.dpreview.com/ for tests on cameraes.
Good pics of the beast Rezz.
Are you doing any more mods to it?
RB26 maybe?
My D70 is for sale if you're interested...
nice pics! pity about the front lip... i was interested also...
You can still get similar front lip spoilers from Yahoo Auctions Japan, and CHARGESPEED make a similar one, although I don't like the shape as much as the BoMeX one.
Btw guys, I really don't have a clue about photography, in fact a goddam chimp chimp.jpg could've fiddled around with the buttons and gotten a better result... I just did some different timed exposures and loaded them up in 'The Gimp' editing software and shapened and brightened them up. Thats all... no tricks.
I posted this in the Photo Diary, but I thought they might get lost up there... so:
Here we go... I got the trusty Nikon D70 out again:
This night shots is a bit vouyeristic... a young lady waiting for the train.
A 300mm zoomed shot 30 sec exposure at f22 with low fluoro lighting white balance adjustment. Oh... it's a HotWorks Factory 1/24th scale BNR34 Nissan Skyline GT-R Z-Tune.
Good timing eh? Hankyu trains passing each other on the Kobe line about 100m east of Hankyu Ashiyagawa station.
Random shot.
While I was taking the train shot, these choppers were circling overhead...
Some nighttime shots from the 6th floor roof of my apartment building.
Try and guess the scale of this Calsonic Skyline GT-R JGTC race car...
You should try to do some artsy shots with some of the modelcars.
I had a link sometime ago to a forum were some guy had taken some pics of scale model of a Honda R-bike and everybody belived it was the real thing.
Are these pics in or around Osaka?
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
