Hi all
Thanks for the great feedback on my previous thread about clutches.
Just got one last thing on my mind right now.
What is the differences between the different amount of pucks on the single plates ? Ok I know the physical differences as Ive seen them for myself....just wanna know the theoretical applications.
Say theoretically, with all things equal. The following clutches were installed on the same car with same driver and same power at all times.
Single plate 9 puck
single plate 3 puck
Twin plate
Which one would last the longest ?
Heard some say twinplates dont last that long compared to singles then the other night a mate swears that his friend wore out a 3 puck single plate in 6 months !!!!! which has got me a little concerned as I have already ordered the 3 puck single ceramic for my car :)
https://www.sau.com.au/forums/topic/78391-clutch-questionagain/
The more pucks the better!
The more surface area you are covering, the less over all wear.
There is alot more strain and wear on 3 pucks then on 9 pucks of equal size, thickness and compond.
The same goes for twin plates, as this states, there are 2 plates of pucks then just the one.
Hope this helps
  shonen said:
ok so would a 9 puck hold just as much power as a 3 puck ??
or would the 3 puck hold more ?
If the 3 puck does hold more wouldnt it balance out in the end ?
ie 9 puck wont be able to hold the power and hence wear out at a faster or equal rate to the 3 puck.
If we are talking about the same clutch and the difference is 3 or 9 puck, well the 9 puck will hold more as long as it is the same size, width & compond as the 3 puck.
When you have more of it to grip with, it will hold more power. Because you have more surface area eg. more pucks - there is more compond to grip the flywheel and pressure plates
  shonen said:
Ok.
Please dont take this the wrong way cause im not doubting your knowledge.
But if we go by your theory shouldnt a full face clutch be better than any "puck" clutch ??
I mean what are the advantages of having the pucks then ?
Yeah you have a point there, When I was replacing the clutch the guys that make them here in Adelaide told me that a clutch with pucks will do better than a full face (performance wise), the full face will be more friendly for day to day driving.
So interested to see who is right here, cause I got a 5 puck one.
If the full face clutch was made with the same compond material as the puck type cluches well it would be better. Most of the time it comes down to manufactering costs. There is no point in placing more pucks or clutch compond if increases the price and does not suit the market intended for.
If you look at a Nismo twin plate clutch, they have almost a full face clutch with the puck style compond which is made up of ceramic compond. The reason for the gaps is heat and the ability for some flex. because these use a large ceramic pad (puck) they are more expensive.
I rang Adelaide Clutches (Xtreme) as they can replace the ceramic pads on them. I almost fell over when then gave me the price, think it was like $1200.00
Reason - it was almost a full face with just some slits in them.
If the clutch was manufactured to hold say 300 HP and it does this with 3 pucks of ceramic pad then way had more? If you added more the clutch price would increase and so would the rated HP.
Another thing you could do is increase the puck's surface area by adding more and decreasing the pressure plate force. You get a softer clutch with the same HP rating but this would cost more as manufacturing costs have also increased.
If you think about it, a twin plate works by have more pads on more metal, silimar to say like having 2 fly wheels and 2 clutch plates. The pressure plate does not have to be very high as there is already alot of compond in contact with metal. Not saying the pressure plates in twin plates are always soft but in the case of the Nismo twin plate, they get a high HP rating cause they use a full face clutch with a medium pressure plate. These are some of the reasons why it holds good power and is light on the foot and behaves like a stock clutch.
I think the terms full face might be misunderstood here.
Is the full face made of the same compond as the 5 puck one?
Usually the full face they speak about is made up of similar compond used in stock clutches but the puck version is made up of ceramic compond. In this case the 5 puck one will do a better jop performance wise.
So if you put a full face and a 5 puck made out of the same material, whatever this may be, the full face one is gonna do better than the 5 puck? :confused:
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
