I've just been mucking around with a Blitz BOV (atmo).. stocker and blocking them both off last few days to compare.
found that the blitz resulted in a bit of a deadspot after a psht even after adjustment.. way too noisy for my liking.
both blocked off, don't notice much difference, maybe a slight stlight flat spot right after, other than the fairly subtle flutter.. I could run this all the time without too much ill effect i think.. not really worried about an old rb20 turbo lifespan, if it does have any effect on that.
then again mine is not running too much boost atm (12psi).. also auto is a differnet thing when it comes to BOV's.. foot off the accel = psht. none on gear changes.
  • Replies 144
Hey all !
I have blocked off my standard bov on my r33 gtst and unpluged the plumback tube from it so it makes a nice fluttering noise, is it ok to be doing that ?
Anyone know which sort of after market blow off valve makes a fluttering noise ?
Wow. Cbf reading all the pages.
My points are probably m00t, but on the NVH topic, this is a extract from an s14 Service manual:
Recirc Valve
EC-17 Nissan S14 Service Manual 1994.
"The recirculation valve reduces the noise occuring in the compressor
of the turbocharger during acceleration. This valve recirculates air compressed
downstream of the intercooler to upstream of the copressor using the intake monifold
vacuum that occurs when the throttle chamber is suddenly closed.
The recirculation valve also must not be disassembled or adjusted. For
diagnosis, refer to EC-206
Also another point which probably has been covered, is that with AFM/MAF bovless or atmo bov, has the same effect of running rich between gearchanges. Atmo bov has a harsher effect, but the MAF/AFM does run rich due to exiting reverb comming out.
Most OEM bovs also dont like high boost. Nissan in particular design them with a SMALL recirc hole which presents a small boost leak the more boost you run. Also most oem bovs are designed to recirc, and do open at idle.
The only bov known to not leak is the toyota Mr2/SSQ type bov, which has a reverse piston design! ie: The more boost you make, the harder the bov piston is shut.
m00000t
steve,
I tried winding it fully tight but it still blows off after 15psi so on the weekend ill try putting a plug in the bov so it doesnt work at all and let you know what happens.
My car runs no afm so it cant be anything to do with the recirculating bov.
The bov is mounted about a foot from the throttle body under the drivers side guard.
An old style HKS sequential (not super) BOV will make the fluttering sound after the usual pssht sound. It has a rubber valve, which i think is why this happens but dont quote me on that.
doesnt go off or is very quiet on gear changes under 3000rpm which suits me fine
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
