Ok guys i got a Wolf 3D version 4 with hand contoller. It is a plug in play ecu for an R33 gtst. It has been tuned for r33 with a turbo back exhaust. Basically a very midly modded car.
Have some pics but are bit too big to post up here reply or pm me and i can email them to you.
Looking for $1000 ono.
Cheers
https://www.sau.com.au/forums/topic/78400-wolf-3d-ver4-suit-r33-gtst/
Cheers
Hey man very interested, do you still have it, can you send pics to
[email protected]
Thanks
James
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
