Hi Guys!!
Jspec Surge Tank: $150 + postage
Jspec Oil Cooler: $ 170 + posage
Both $300
pics below:
Surge Tank
Oil Cooler
Oil Cooler-
This unit is capable of supporting enough Oil flow for engines in excess of 1000 horsepower, and is ideal for forced-induction engines but all N/A Cars will benefit from Having an Oil cooler of this Quality
core size is 600x120x70
you can request if you want it polished or with a silver anodized finish
(no cost difference)
also has the brackets already welded..
Also the fittings on the oil coolers are able to be put on the one side but there is an extra cost because we need to put a separator/divider in the end tank that supports the outlets, 10$$ extra fee for this requirement, also the core is a bar and plate Garrett intercooler
Surge tank -
1.5 litres and has 10mm fittings; it is 80mm thick by 250 in height, also has the fuel pump bracket fixed in so your fuel pump is safely connected at all times
Cheers,
Jase
https://www.sau.com.au/forums/topic/78402-surge-tanks-oil-coolers/
what 1,000 hp cars are using the oil cooler of this design at the moment? did you ask Garret about whether their core is going to cope with the hydrolic pressure? (you can't compress liquids at all unlike air).
also the piping pictured on that oil cooler kit isnt going to last very long either, try braided or at the very least teflon reinforced high pressure hose. The temperature and pressure will eventually blow that type of hose appart.
    • Duncan:- it affect both sides.  Driver side is worse.
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
