hey all.. search turned up dry
i am currently losing coolant on my rb20, with a pressure test it reveals coolant trickeling out the bottom of the timing cover
im geussing this would be the water pump seal so its time to rip it apart.... again!
is the removal of timing cover fairly simple or does the CAS have to be removed to gain access?
my search should of turned up with an answer for this but no luck so any help would be great.. also ive read that rb30 pumps fit so im guessing the gasket is gonna be the same?
cheers guys
https://www.sau.com.au/forums/topic/78405-suspected-leaking-water-pump/
