I beleive that my alternator is starting to die. My mechanic has stated that due to it being a "Mitsubishi" alternator, they can not be reco'ed and Bosch has not yet released and "aftermarket" replacement for the R33.
Has anyone replaced a r33 s1 alternator?
Where did you find a replacement?
How much did it cost?
Was it a direct (no modification required) fitment?
Or has anyone actually managed to reco the std alternator?
ANY HELP ADVISE WILL BE APPRECIATED :)
Thanks
Alan
PS: I do not wish to buy a 2nd hand unit as these are now over 10yrs old. Nissan unfortunately sell these for about $1300 :).
https://www.sau.com.au/forums/topic/78420-r33-s1-alternator/
when mine died for the s2 just an auto elec i found in the directory changed my stocker to a mitsubishi one, was $450 odd fitted. just direct swap in, swap out. probably doesn't help. the place is in sunshine, on mcintyre rd.
If you can pull it apart you might find the brushes are worn down. New brushes are only about $20. Could also be the voltage regulator but more likely the brushes.
If it spins fine with no noise the bearings are ok.
Mechanics and auto electricians often don't like pulling things apart. Happened with a toyota I had. Wanted $350 for a new one. I pulled the old one apart put new brushes in - worked till I sold the car (a couple of years)
You could get a cheap 2nd hand one. Wack it in - then try and refresh your old one. Put that back in and sell the 2nd hand one for what you paid.
Or talk to an auto electrician that is willing to rebuild your one approx 100-300 I would think
  • 5 years later...
Bringing this one back! Lol. Just wondering if anyone knows of a direct bolt in 120a+ alternator for a series 1 r33 rb25de?
http://www.skylinesaustralia.com/forums/R3...ment+alternator
If i'm reading correctly, an aussie R31 with an RB30's Bosch 110a (close enough) is a direct fit, can someone confim that please? I have searched, and the above link is the closest I got. Any help appreciated. :banana:
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
