266 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I back it out of garage, lock garage, then driveaway. So it idles for 1-2mins,
then my road is a dirt road, so i sit in 2nd at 2000 up it (2-3 mins)
then I take it easy until I reach the nearest town (5 mins) then after that I drive it however I want.
if im bothered i turn it on in the mornings before work, put my turbo timer on for 5mins, take my keys out, lock the car and go get dressed.
thats when im bothered though. otherwise ill just drive off but taking it really easy.
my car sits in the shed all week, so i warm it up fully before i drive it, ill start it after getting dressed, then ill come back in, brush my teeth and do whatever, good 5-10min idling in shed, then backing out of the shed, i have to get out and close the door, then i have to get out and open and close the front gate, then my driveway is about 400m of dirt, so its usually idling all the way down there, dont go over 10kms, so theres a good 5 min, then its another 700m to the end of the laneway, i drive down there in 2nd gear bout 2000rpm. then its straight onto an 80km p/hr main road. so i cruise along there for 2km....by that stage, its fully warmed up.
the work truck.....pfft....i barely let the glow plugs heat up before i start it and drive off....good thing the lines not a daily driver.
cheers
Linton
The longer it takes for the car to warm up, the more damage is occuring internaly.
Your better off just driving it sensibly, the car warms up faster and your not wasting your time watching a gauge slowly creeping up to normal operating temp :(
I sometimes let it warm up: depends how long its been sitting and how much of a hurry I am in.
If its dead cold (the car) it usually is a pig to drive for the first few minutes anyway (weeee... cold start mode), so it barely gets over 2,500RPM until water and oil temps are up.
LW.
I dont think anybody Warms there car by letting it sit there for 10mins
My GTST is a daily driver into perth and weekends (Love it too much)
I have Expencive oil (Motorbike to be exact) good $80 a bottle
I start it up wait about 10secs then start to back it out. When im driving to work I dont go over 3,000 most changes are around the 2,000 or 2,500 but when she warms :) I have fun
I let the car get the oil temp up and water temp close to up to operating temp.
Why does idling it does more harm than good?
B/C on idle, the mixtures are rich and are washing the oil off your cylinder chambers, causing more engine wear.
7yphon has the right idea, that is the best way to prolong engine life.
I usually wait until the oil pressure goes up before driving, so it is after 10 seconds or so.
Just drive off, and take it easy. You gearbox and diff need to circulate oil too you know
Mine is turning into a weekender.. I live too close to work now!
Of a weekend Id start mine, drive it out of the garage, close the garage door, check the mail, get back in a drive off most times. I spose its about 30 secs all up. As everyone had said I nurse it around for the first 10 kms or so, then into it.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
