266 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I back it out of garage, lock garage, then driveaway. So it idles for 1-2mins,
then my road is a dirt road, so i sit in 2nd at 2000 up it (2-3 mins)
then I take it easy until I reach the nearest town (5 mins) then after that I drive it however I want.
if im bothered i turn it on in the mornings before work, put my turbo timer on for 5mins, take my keys out, lock the car and go get dressed.
thats when im bothered though. otherwise ill just drive off but taking it really easy.
my car sits in the shed all week, so i warm it up fully before i drive it, ill start it after getting dressed, then ill come back in, brush my teeth and do whatever, good 5-10min idling in shed, then backing out of the shed, i have to get out and close the door, then i have to get out and open and close the front gate, then my driveway is about 400m of dirt, so its usually idling all the way down there, dont go over 10kms, so theres a good 5 min, then its another 700m to the end of the laneway, i drive down there in 2nd gear bout 2000rpm. then its straight onto an 80km p/hr main road. so i cruise along there for 2km....by that stage, its fully warmed up.
the work truck.....pfft....i barely let the glow plugs heat up before i start it and drive off....good thing the lines not a daily driver.
cheers
Linton
The longer it takes for the car to warm up, the more damage is occuring internaly.
Your better off just driving it sensibly, the car warms up faster and your not wasting your time watching a gauge slowly creeping up to normal operating temp :(
I sometimes let it warm up: depends how long its been sitting and how much of a hurry I am in.
If its dead cold (the car) it usually is a pig to drive for the first few minutes anyway (weeee... cold start mode), so it barely gets over 2,500RPM until water and oil temps are up.
LW.
I dont think anybody Warms there car by letting it sit there for 10mins
My GTST is a daily driver into perth and weekends (Love it too much)
I have Expencive oil (Motorbike to be exact) good $80 a bottle
I start it up wait about 10secs then start to back it out. When im driving to work I dont go over 3,000 most changes are around the 2,000 or 2,500 but when she warms :) I have fun
I let the car get the oil temp up and water temp close to up to operating temp.
Why does idling it does more harm than good?
B/C on idle, the mixtures are rich and are washing the oil off your cylinder chambers, causing more engine wear.
7yphon has the right idea, that is the best way to prolong engine life.
I usually wait until the oil pressure goes up before driving, so it is after 10 seconds or so.
Just drive off, and take it easy. You gearbox and diff need to circulate oil too you know
Mine is turning into a weekender.. I live too close to work now!
Of a weekend Id start mine, drive it out of the garage, close the garage door, check the mail, get back in a drive off most times. I spose its about 30 secs all up. As everyone had said I nurse it around for the first 10 kms or so, then into it.
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
