TracidTrax Posted June 29, 2005 Author Share Posted June 29, 2005 I like one of the previous posts about the Turbo TimerGo set it for 10 mins and lock the car. Jump in and set to go! Got me looking now for one. Be worth the $120 to be able to have a nicely warmed motor. Particularly after a night shift when I'm straight out the door and into city traffic and duckin' weavin' No time for warm ups there! u could do that or u could just get a remote engine starter like me and turn the car on from inside the house and let it idle for a bit Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1438364 Share on other sites More sharing options...
wishaw Posted June 30, 2005 Share Posted June 30, 2005 you only really need enough time for everything to be covered in oil. 30sec to a min should be plenty of time. Idling might help with lubing up the engine but the cat doesn't like it and will kill it faster. Correct me if i am wrong but after everything is covered in oil the only problem is parts heating up (expanding) at differnt rates. So if you wait untill the water is up to temp then the whole block should be nice and warm due to the hot radiator fluid running through everywhere. So once your water temp is up you should be right to have some fun. Aslong as you don't thrash it for the first few minutes it will be fine. Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1438553 Share on other sites More sharing options...
dayne Posted June 30, 2005 Share Posted June 30, 2005 I usually back out of the garage, and close it (around 30secs) and then take off slowly until i get out of my suburb (3-4mins) When i start my car however, the oil light stays on for about 2seconds then goes off.. is this normal?? The oil atm is sitting halfway inbetween L and H (on the dipstick) Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1438605 Share on other sites More sharing options...
wishaw Posted June 30, 2005 Share Posted June 30, 2005 most oil lights weill stay on for a few seconds. AS long as it turns off and stays off then you should be fine. Aslong as you check you fluids regularly (AS WE ALL MUST) there will be no problem. Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1438616 Share on other sites More sharing options...
someonestolecc Posted June 30, 2005 Share Posted June 30, 2005 Just drive straight off and don't boost or rev too much for the first 5 miuntes!! If you idle for longer thatn 20 seconds you are: 1. Wasting fuel 2. Increasing pollution 3. Wasting some of your life 4. NOT doing your car any favours. These are modern cars. They are made to be driven straight off. CASE CLOSED My car won't move if I don't idle it for atleast 1-2mins. It just dies if you put the accel in. My car is also not stock, so it wasn't "made" to be driven straight off it was made to make more power, handle better and stop better. Does that mean I'm injuring it and I should try to make it be able to take off in around 20secs? Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1438618 Share on other sites More sharing options...
dayne Posted June 30, 2005 Share Posted June 30, 2005 most oil lights weill stay on for a few seconds. AS long as it turns off and stays off then you should be fine. Aslong as you check you fluids regularly (AS WE ALL MUST) there will be no problem. Thanks for clearing that up, i was starting to worry!! I check it 1-2times a month. Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1438654 Share on other sites More sharing options...
wishaw Posted June 30, 2005 Share Posted June 30, 2005 My car won't move if I don't idle it for atleast 1-2mins. It just dies if you put the accel in.My car is also not stock, so it wasn't "made" to be driven straight off it was made to make more power, handle better and stop better. Does that mean I'm injuring it and I should try to make it be able to take off in around 20secs? Are you running an a/m ecu? Your car shouldn't really die if you put your foot down when it is cold. If you have done any engine mods then warming it up at least a little bit would be a good idea. But the best way to warm up your car is to baby it on the streets. Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1438732 Share on other sites More sharing options...
RB30-POWER Posted June 30, 2005 Share Posted June 30, 2005 It obviously has a bad tune if it stalls. Simple as that. I dont care how worked the motor is, they can all be tuned to drive nicely with the right hardware. Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1439500 Share on other sites More sharing options...
jezzerrr Posted June 30, 2005 Share Posted June 30, 2005 idle for a minute or so, then take it easy till i see some decent temp, usually about 10 minutes or so. which sucks cause it only takes about 10.5 minutes to get to work! Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1440321 Share on other sites More sharing options...
Topaz Posted June 30, 2005 Share Posted June 30, 2005 I just take it slow while temp is getting up there... but its always in the garage which I close after reversing out Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1440476 Share on other sites More sharing options...
wishaw Posted June 30, 2005 Share Posted June 30, 2005 idle for a minute or so, then take it easy till i see some decent temp, usually about 10 minutes or so. which sucks cause it only takes about 10.5 minutes to get to work! Sounds like you need to find a longer way to work. Have you guys had a lok in the car manual (if you got it) I have had a look through a few differnt cars manauals and they all say the best way to get the car up to temp is to drive it normally. They also say that excessive idling with kill your cat(if you have one). Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1440701 Share on other sites More sharing options...
meep Posted July 1, 2005 Share Posted July 1, 2005 u could do that or u could just get a remote engine starter like me and turn the car on from inside the house and let it idle for a bit i hear that, i also just hit the auto start have breakie and then take off Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1441043 Share on other sites More sharing options...
wilch Posted July 1, 2005 Share Posted July 1, 2005 idle for a minute or so, then take it easy till i see some decent temp, usually about 10 minutes or so. which sucks cause it only takes about 10.5 minutes to get to work! Me too!! I take a detour when going to work now though. It's still only takes about 15mins, use to take 10. Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1441669 Share on other sites More sharing options...
knore Posted July 1, 2005 Share Posted July 1, 2005 A good 4min every time, without fail Neighbours love me :uh-huh: Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1441781 Share on other sites More sharing options...
Ska Posted July 1, 2005 Share Posted July 1, 2005 Does bouncing it off the rev limiter count as "warming"? If so then yeah I do that Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1442199 Share on other sites More sharing options...
scathing Posted July 1, 2005 Share Posted July 1, 2005 Yeah, I have a "startup routine" in the morning. Get in the car and start it up. Then put the belt on, turn off the TCS, and adjust the stereo. Maybe clean out the centre console of the various bits of paper that gather in there. When I see the revs drop from its "cold idle" 1500RPM and the oil pressure drops from 6kPa, I'll drive it at low RPM and load for a while. Luckily there's downhills away from my street, so I'll just select whatever gear keeps it at the speed limit without using the pedals for as long as I can. Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1442419 Share on other sites More sharing options...
Cubes Posted July 1, 2005 Share Posted July 1, 2005 6kpa.. Is this a RB20DET or RB25DET? I find the RB25DET oil pump shoots oil pressure up over 8kpa in the mornings. Once warm and with over 4000rpm on board oil pressure is around 6.5kpa. Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1442697 Share on other sites More sharing options...
scathing Posted July 2, 2005 Share Posted July 2, 2005 VQ baby. Its the way of the future Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1443130 Share on other sites More sharing options...
Links Posted July 7, 2005 Share Posted July 7, 2005 Tend to warm it up atleast until the oil temp stabilises.. once it's there - i'm happy.. it's happy.. not good for any cars to just start up and thrash off, can cause a bit of damage - I think.. might be wrong though.. bit like stretching before going for a run eh! if you don't do it, you'll regret it.. if you do - everything is sweet.. Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1451381 Share on other sites More sharing options...
warriorbrawl Posted July 7, 2005 Share Posted July 7, 2005 im with you tommO just stay off boost and it will be fine 5 mins ideling in the shed and it would be a gas chamber in there. Link to comment https://www.sau.com.au/forums/topic/78450-do-you-warm-your-car-up/page/3/#findComment-1451691 Share on other sites More sharing options...
