266 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
reinforcing the last comment, has anyone noticed how long it takes for a car to warm up at idle? so thus you are running the car "cold" for longer? there has to be a middle ground. for me, it's taking it easy for the first 5-10 minutes of driving.
have you guys ever watched a F1 race car warm up from cold ... they rev them at a particular rev range at given tempretures as the car warms up to minimise the cold rattly pistons bashing around in the cylinders thus reduce engine wear ...
also i think somewhere i read the 75% of engine damage occurs in the first 5 mins of a car starting because it is outside its optimal heat range so getting the car to its optimal heat range as quickly as possible by driving it (within limits of course ... i dont mean that as soon as you start the car you have to dump a second gear burnout :D ) would be the best way to go?
Excuse the ignorance if i am wrong =P
They also heat the oil up to temperature before pouring it into the engine, to make further reduce the time it takes for your engine to warm up (which, in most cases, is to ensure the oil has enough heat to reach the proper viscosity).
IMO, 10-15 minutes is wayyy too long. Just a waste of fuel!!
Yeah but, the needle on the temp is just creeping up almost half way and the oil temp is just starting to move once I hop in. It's a small price to pay for proper maintenance.
No its not, thats 15minutes of the engine running at sub operational conditions hence more wear and tear, also running it at idle for 15mins would start to glaze the bores wouldnt it?
I think this would be doing more damage then its preventing, also your gearbox and drivetrain wouldn't be warmed up either.
get dressed for work, start car, set turbo timer on 10mins, go do everything else i gota, come back out about 7mins later and take it easy till is about 1/3 - 2/4 of the way up, then have a lil fun when i get to the 80-90 zones.. mmm windy fast roads *drool*
edit: although after reading what every1 has said, i mite not warm it up for as long from now on.. just a min or 2 then drive like a granny till she warms up.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
