  • Replies 95
Oh yes... And a little extra "kick" in case anyone with a couple of GT-RS's tries to pick a fight :)
hehe...maybe i shall run 25psi myself just to lift the bar a little higher :( 380awkw+
i can then look at NOS to add icing :)
hehe...maybe i shall run 25psi myself just to lift the bar a little higher :) 380awkw+
i can then look at NOS to add icing ;)
Marko,
I can't remember what the compressor flow map for the GT-RS looked like, but I'd be surprised if you couldn't run upto 1.8 bar (26 psi) on those babies bigthumb.gif
30psi!!! DOOO EEEET!!!! :uh-huh:
It's all about how you look at things ;) For example:
If you blow your gearbox, it's a good excuse to whack an OS Giken or a Pfitzner gearset in there :)
If you blow your engine, it's a good excuse to put in that stroker kit ;)
See? That should be more than enough incentive to wind it up and see what she'll do :uh-huh:
I plotted Marko's torque curve against mine just for interest sake...
Marko's might be alittle off but thats as close as i could match em...
The GT-RS's are making 1000nm torque more then the GT-SS as they are both dropping off which should give considerably more top end!!
noice. one thing though. those graphs show N (measuring 'tractive effort') not Nm (newton metres). one of my pet annoyances...!
Whats the conversion from N to Nm ??
It's not that simple, one (tractive effort (N)) is a linear force, and the other (Torque (Nm)) is rotational.
Also, torque is affected by gear ratios.
Theorectically, if you multiply the tractive effort by the radius of the tyre, you will get the torque in Nm at the wheel, but this will be different to that at the engine.
Dynolog dynos somehow read torque at the engine, and they manage to do it quite accurately. There is one on the South Coast that read 390nm for a stock standard GT3 and just over 500nm for Gallardo.
yep, there is no simple way to convert N to Nm. it really pisses me off. would love to know how much torque my car makes.
Put it on an engine dyno whilst you have the engine dropped to install sump baffles/extension :);)
Hey guys,
Do you think my GT-RS on my sr20 will pull close to these figures :) hehe.
Its get tuned at CRD late next week...
I know that GT-SS don't make over 230rwkw on sr20's.
On the other hand I have seen a dynograph of 280+rwkw with a GT-RS on an sr20.
Its great to see some comparisons.
-Dan
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
