Howdy,
Just had the car tuned recently, and its making more power obviously.
With my 2 way diff, you can feel the rear end move around now.
I need advice on how to stiffen the rear....
Do I replace the bushes with std ones, or go the Noltec urethane ones?
How much NVH does the urethane ones add to the car? Car is mainly a road car with some track work intended in the future.
Which "pineapples" do people suggest - the alloy ones, or the other urethane ones?
Im thinking of going for the Noltec, with the alloy mounts but dont want the ride to become a rattle box.....
https://www.sau.com.au/forums/topic/78479-sub-frame-movement/
get alloy subframe spacers/pineapples. They apparently make a huge difference, no more axle tramp!!
There is a thread on them on http://www.nissansilvia.com/forums/index.p...showtopic=84489 a couple of people mentioned u don't get much more drivetrain noise
IMO i woudn't bother with the urethane ones, i'd just go straight to the alloy ones. I have some ready to go into my car, just c.b.f'd installing them.
What sort of track work? drift??
(If you want to buy a set, PM me)
I dont have axle tramp at all suprisingly. I wanna replace the mounts first, then move onto
these alloy pineapples....
Car is mostly street driven, with the odd track in the future. No drift, just circuit :( Maybe drags if i feel like having a number....(pmk me what you can get them for :))
cheers.
go the alloy pinapples. urethane ones require new bushes to be fitted for best handling. alloy ones squash everything up and make it so it cant move.
i have the alloy ones, they made a huge difference, i set them up for drift and could instantly feel the difference when sliding....the back end hangs out alot longer and easier.
cheers
Linton
ohh, i'm gonna get off my arse and put mine in..... my rear end is crap coz of soft coilovers. I just put a rear strut brace in and it makes a big difference for drift, this should make it even better.
in fact, if you don't have one, i'd also suggest a rear strut tower brace
http://www.skylinesaustralia.com/forums/sh...ead.php?t=77338
hi, ive got the noltec subframe bushes( not pineapples) in my car and I dont notice any increase in road noise/ harshness at all.
I also have new rear rack and hub bushes(nissan rubber) - done after subframe bushes fitted - so everything is pretty much new and tight and still dont feel any harshness at all. The car really holds the line well in the rear now, more noticeable improvement after doing rear rack and hub bushes than that felt when the subframe bushes were fitted first. Feels more positive on the track also, showing up the failings of my tyres as they do the squirming under load rather than the old subframe bushes that wiggled the car around corners!
A mate has noltec subframe bushes in his 32 GTR and I havent noticed any change in noise/ harshness.
What is the difference between subframe bushes and pineapples.I was under the impression that they were one and the same,just given different names by different people.
as gts4diehard is saying.. rear rack ends are probably a good idea to replace too if you're doing the subframe bushes, as they will firm up the rear, and stop some movement there as well.
as pointed out by the suspension place I got the work done, even if you lock the HICAS.. you still have something decent on the ends to hold it in place :)
Made a bit of a difference in mine at higher speeds with a firmer feel
Replacement bushes (alloy or polyurethane) are NOT the same as "pineapples".
Replacement bushes simply replace the standard rubber bushes with a firmer (hardness) material. In the case of aluminium that is solid, which is not a good idea as it can lead to cracking of the subframe mounts. Nissan designed the rubber bushes to prevent this and to lower the NVH. Polyurethane is a good mid ground, it is much firmer than rubber (45 versus 90 duro) but it has some give to keep the NVH within reason and to prevent the chassis cracking under the vibration.
Pinapples are "tuning" device, by placing them above and/or below the subframe you can tune the amount of antisquat. More squat for drags gives better traction and faster launch. Lots of antisquat for drift to decrease the traction and enables easy/earlier slide.
Pineapples do add a worthhwhile amount of extra rigidity when used with the standard rubbers. But they make no difference to rigidity when used with aluminium bushes and very little difference when used with polyurethane bushes.
Hope that helps ;)
Nissan don't supply replacement subframe bushes.
They said they are not servicable.
its the same for even their Aus released cars. 300zx etc, no supply. :)
I think Nismo make "hardness up" rubber bushes:cheers:
Pineapples still sound like a goer with a whiteline kit.Ie:the extra urethane bushes that come with the kit.
But then would it or would it not show up the weak links in the cars handling.Like the tyres.
Is the 1degree +/- camber for the front,supplied in the whiteline kit as an extra,enough for most spirited weekend drivers.Or would stock camber up front suffice.
1. But then would it or would it not show up the weak links in the cars handling.Like the tyres.
2. Is the 1degree +/- camber for the front,supplied in the whiteline kit as an extra,enough for most spirited weekend drivers.
3. Or would stock camber up front suffice.
Hi Trust33;
1. The weakest link is always the weakest link, but there is no doubt that more contact patch from less roll will help any tyre.
2. When you lower them they end up at 1 to 1.5 degrees negative anyway, then add the Whiteline adjusters and you usually get 2.5 degrees negative. Which is not a bad place to start
3. Nope
:D
    • If you want to do the wiring, the GTT engine ecu has the same pinouts extra that the seperate TCM in the NA car has. You can literally grab the wires/pins that lead into the Seperate TCM and wire them into the corresponding pins in the GTT Engine ECU. You could then in theory Nistune it. I realised this when everyone put it in the too hard basket and I actually looked at the f**kin R34 manual. This is after I had previously had a seperate aftermarket TCM controller in my original N/A chassis car and a very built gearbox from a GTT, running a seperate Haltech engine ECU. I ran into this issue when I re-shelled the car into a GTT shell, so my aftermarket TCM was no longer plug and play, because the loom/modules were not present. I was pretty livid when realizing just how simple the original fix actually was. It sat for 3+ years at various workshops trying to find a solution. In practice none of this is a worthwhile idea for a lot of reasons, generally surrounding the shitness of the NA auto, the autos in general that come with skylines, and the NA engine and lack of gains. The gearbox is specced for the 2.5L N/A and barely at that level. If you have to pay anyone any money to do any of this, that is money spent on manualizing the car and it's not even close in terms of a comparison. Learning to drive manual is simpler than going through the pain of dealing with the N/A gearbox and he'll have fun to boot.
    • Semi-correction to my blanket statement that you can't bend rubber hoses. It seems that you can get most of a result, by doing as this guy does. I wouldn't promise that the bends will stay in the hose forever. I think if I found they wouldn't stay, I'd get a larger hose and cut some 90掳s out to go over the bends I wanted to be in the smaller hose, as a reinforcement.
    • Just a heads up. Mine has just failed. When i turn the car on it just reboots everytime then the word "Android" shows up then goes to a black screen. I've aksed the company i got it from for some help but it's passed their 90 day return so they wont help. I have to swap back to my old system this weekend 馃槶
    • Does the car have to stay auto? If so, you might be looking at a ZF swap in future.
